oil cooler install pics!
Old 08-05-2005, 10:01 PM
drift2004's Avatar
Default oil cooler install pics!
car 91 integra others may be different but almost the same
most people say you dont need to run an oil cooler, i say bs run one anyways if you want you car , they even did a test in sport compact magazine that they saw an increase in spool up from the oil cooler any one remeber this issue? , better do it right the first time. total cost was $ 327 dollars at jegs.com im not responsible for you damaging your car.
first you need to get all the parts these are all the parts i used.
Qty. Item Item Price Subtotal
1 Aeroquip AQP Stainless Steel Braided Hose - AN Size: -08; 15 Foot Length
023-FCA0815 $70.88 $70.88
6 Earl's ''AN to NPT'' Adapter Fittings - -08AN to 1/2''NPT
361-981688 $4.99 $29.94
1 Catalog Item - Perma-Cool ADAPTOR
771-186 $27.99 $27.99
1 Perma-Cool Remote Oil Thermostats - 1/2''-14 NPT Ports
771-1070 $39.99 $39.99
1 B&M Hi-Tek Trans Coolers - SuperCooler 28,000 GVW (11'' x 8'' x l.5''), (1)
130-70266 $59.99 $59.99
8 Aeroquip ''AN'' Reusable Swivel Hose End Fittings - -08AN Straight Swivel
023-FCM1013 $7.99 $63.92
1 Perma-Cool Weld Bungs - 10 AN Male
771-15609 $4.99 $4.99
2 Aeroquip ''AN to NPT'' Adapter Fittings - AN Size: -08; 3/8 Pipe
023-FCM2037 $9.99 $19.98
Subtotal $317.68
Handling $9.99
TOTAL $327.67
1st
[IMG]Qty. Item Item Price Subtotal
Subtotal $317.68
Handling $9.99
Ground Delivery Charge $.00
TOTAL $327.67
you can do the hose your self it does take time to put all the fittings in, justi think its one of the most time consuming
i took out the headlight to see how i was going to route the lines, u dont really need to but ii learned that too late, well i hide my wiring so that was good , this is for a DA integra
drill a hole to hold the oil cooler
mount the cooler
make sure uyou use teflon tape to prevent any leaks, and do not put it right next to the tip of the treads because it can go in to your system at least 2 treads back and your cool
make sure you tighten them i used a 23mm socket
once you mount the oil cooler you might have a problem making the lines fit, i dint want it to rub the part of the structure of the car , just incase vibration or anything may break the line so what i did was...
fold her back and your cool
this is how the lines come out when oil cooler install the lines are appx. 1 foot long
then make some more 2 lines appx 3 1/2 foot long
put all the an to npt adpater on the thermostat
it should hold like that
next put the 90 degree fittings on the sandwich first remember teflon tape!
then un-screw your oil filter
and you should see this
then put the lines are ur done
Old 11-21-2005, 06:05 PM
Cory Matthews's Avatar
Default Re: oil cooler install pics! (drift2004)
good stuff
Old 11-21-2005, 06:15 PM
Integra Integra's Avatar
Default Re: oil cooler install pics! (z6 coupe)
Hey good stuff but please change that FRAM oil filter FRAM is the cheapest quality filter out there get a Purolator or a Mobil 1 there 10x better check out BobIsTheOilGuy.com for more tips.
Old 11-21-2005, 07:40 PM
Squrtin DC2's Avatar
nice write up
Old 11-21-2005, 08:50 PM
R4ND0M's Avatar
Default Re: oil cooler install pics! (Integra Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Integra &raquo;</TD></TR><TR><TD CLASS="quote">Hey good stuff but please change that FRAM oil filter FRAM is the cheapest quality filter out there </TD></TR></TABLE>
Source?
Old 11-21-2005, 08:54 PM
Lauj87's Avatar
any notice able power gains?
Old 11-21-2005, 09:02 PM
1997GS-R's Avatar
you should have used the yellow teflon tape which is for high temp/gas/oil applications
other than that looks good....nice write up
Modified by 1997GS-R at 1:14 AM 11/22/2005
Old 11-21-2005, 09:15 PM
Default Re: (Lauj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">any notice able power gains?</TD></TR></TABLE>
ahaha you are quite the joker.
Old 11-22-2005, 03:06 AM
Default Re: oil cooler install pics! (Rand0m)
Drift- My source is BobIsTheOilGuy.com and its been explained how cheap they are there valves are weak and the paper lining may burst. Search "FRAM" on that site see how many people took them apart and look how cheap they are. The only FRAMS I will ever use are the X2 ones which are OK not the best but decent
Old 07-05-2013, 04:48 PM
unuselectus's Avatar
Any more recent write-ups with pictures?
acrocat
07-05-2008 10:39 PM
esteen2
10-11-2006 07:49 PM
drift2004
08-06-2005 01:53 PM
DC2TT
05-10-2005 07:56 AM
delux247
Honda S2000
01-04-2004 07:01 PM
Quick Reply: oil cooler install pics!
