Header benefits on a d16y8??
Old 06-17-2005, 03:59 PM
G-CIV's Avatar
Default Header benefits on a d16y8??
Do any of you guys know if it will make much of a difference in my 97 civic coupe ex coupled with intake and exhaust piping at 2.25 and a high performance muffler to place a header on it?
I've been considering the DC Sport 4-2-1 two piece, and does anybody know much about that header(clearence, quality,etc...)
Will it make much of a difference in my power????
Modified by G-CIV at 5:15 PM 6/17/2005
Old 06-17-2005, 06:40 PM
Revolver's Avatar
Default Re: Header benefits on a d16y8?? (G-CIV)
If you search at all you will find something usefull. Take a note: typically, using an aftermarket header will be one of the most noticable power gains. This is true for practically any make or model. Non FI of course.
Old 06-17-2005, 07:13 PM
G-CIV's Avatar
sweet, thnx for the info,...does an aftermarket intake manifold make much of a difference? like the skunk 2 one?
Old 06-17-2005, 07:25 PM
Revolver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-CIV &raquo;</TD></TR><TR><TD CLASS="quote">sweet, thnx for the info,...does an aftermarket intake manifold make much of a difference? like the skunk 2 one?</TD></TR></TABLE>
Not as notable. The intake manifold goes up in effectiveness the more HP you create
Old 06-27-2005, 10:14 AM
G-CIV's Avatar
Default Re: Header benefits on a d16y8?? (Revolver)
so should i buy some haeders? i mean is the difference that i will notice be worth the $250 that i would spend on some header?!
Old 06-27-2005, 10:24 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-CIV &raquo;</TD></TR><TR><TD CLASS="quote">so should i buy some haeders? i mean is the difference that i will notice be worth the $250 that i would spend on some header?!</TD></TR></TABLE>
You need to spend quite a bit more time researching this site, because you've asked alot of general questions so far.
You will spend alot of money on bolt ons for that engine, and maybe gain 10hp. It's not a good $/hp benefit; and you probably won't notice any difference on the street.
You should make a plan of ultimately where you want to go. If you really want to make some power, you'll either need to build or go FI, that's where these extra parts start giving some gains by optimizing your system.
I'd wait a while, figure out what you really want to do with the car, then start researching what parts will work best for your needs and application. But if you really just want to mod your car to mod or whatever, then go ahead, but you may realise later that you wasted the money and have to buy the parts all over again.
Old 06-27-2005, 11:26 AM
EricUSC's Avatar
Default Re: Header benefits on a d16y8?? (AutoXer)
A 4-2-1 header is the way to go for daily driving for it gives the best mid-rpm gains. A 4-1 header gives better high-rpm gains, but not much mid-rpm gains if any. You will probably get at most 5 hp from a 4-2-1 header on a D16Y8. Here is a dyno graph from a Comptech 4-2-1 header on a D16Y8:
http://www.comptechusa.com/ima...t.pdf
bigmacnfries
Honda S2000
03-30-2008 05:01 PM
Probot
03-24-2007 09:28 PM
bsixteen
05-30-2004 08:34 PM
civickidd99
11
10-11-2003 12:00 AM
FR-MOB: ThE bEe GuY
04-29-2003 09:03 AM
Quick Reply: Header benefits on a d16y8??
