Help with PCV Valve for Civic EX 1999
Old 04-28-2005, 05:35 PM
mushu315's Avatar
Default Help with PCV Valve for Civic EX 1999
I searched everywhere...
I found one diagram, but i dont understand it, and i still can't find it.
can someone post up a picture of the actual engine and location of the PCV Valve?
I found pics for Accords, cRX, but no Civics
Thanks
Old 04-28-2005, 06:22 PM
Bond's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (mushu315)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mushu315 &raquo;</TD></TR><TR><TD CLASS="quote">I searched everywhere...
Thanks
I would start off by looking at the intake manifold .
Old 04-28-2005, 07:05 PM
92civic_eg's Avatar
hello
it is under the intake manifold,which you would need to go under the car and replace it
Old 04-28-2005, 07:30 PM
Bond's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (92civic_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civic_eg &raquo;</TD></TR><TR><TD CLASS="quote">hello
it is under the intake manifold,which you would need to go under the car and replace it</TD></TR></TABLE>
Well I don't know about that. On EG's they are on top of the intake manifold close to the valve cover. I can't see why they would put it underneath on the 99.
Old 04-29-2005, 06:21 AM
EE_Chris's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (Bond)
Why don't you just get underneath and look up above the oil filter - it IS underneath the manifold.
Old 04-29-2005, 06:47 AM
flood's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (EE_Chris)
Correct its under the intake mani.
When you change the oil is the best time to do it. Take off the oil filter and there is a black box just above it. Plugged into the black box is the PCV valve with attached hose. You can pop it out carefully with a screwdriver. Then crawl out from underneath your car (safely supported with jackstands) and pull the hose that the PCV is attached to from between your intake runners and pop in the new valve. Crawl back under and put it in the black box. Finish oil change.
Old 04-29-2005, 07:32 AM
#1 Super Guy
94eg!'s Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (flood)
It took me and my friend about 20 minutes to find it on his EX. I couldn't believe they started putting those things underneath the intake manifold. They are hard enough to get out when there on top. Good thing he had small hands and could get the stupid thing out of the oil separator can though. I couldn't even get my hand in there far enough to get a thumb on it.
Old 04-29-2005, 08:17 AM
sohcmasta's Avatar
well, they're not exactly an everyday maintainance kinda thing, so it makes sense to put them outta the way.
Old 04-30-2005, 02:34 AM
mushu315's Avatar
damn, that's a pain.
so if i want to replace it, do i just pull it off?
anything special i gotta do?
THansk
meagainsttheworld
30
08-27-2006 06:09 AM
Kapetan
05-31-2006 09:39 AM
coupon
12-11-2004 04:36 AM
..::91TEG-G2::..
11-16-2004 09:50 AM
xsoofreshx
06-20-2004 05:32 PM
Quick Reply: Help with PCV Valve for Civic EX 1999
