$$$price of ls/vtec conversion
i just want to know around how much does a lsvtec conversion cost...it feels like im getting ripped off....$2500 b16a head
Re: $$$price of ls/vtec conversion (ecks_fourttwo)
Bout ta build mine for around 2 grand. Heres my setup.. https://honda-tech.com/zerothread?id=1188326
Re: $$$price of ls/vtec conversion (JdM DA InTeGrA)
Mine was about $3100, that's not including labor cause we installed her ourselves. also the block was mine. i had to get everything else.
1998 B18B Block (honed, hot tanked, and thoroughly inspected)
LS Crank (balanced {cam to flywheel} and micropolished)
Modified ITR Main, Rod, and Thrust Bearings
LS Rods (ARP lock bolts)
B18C5 P73 Pistons (New)
P73 Piston Rings
B16 Head reconditioned w/new valve job,etc...
B16 Intake Manifold
ITR Oil and Water pumps (New)
ITR Crank pulley
LS Oil pan, windage tray, and pickup
NGK Spark Plug wires w/plugs
Hondata Intake Manifold gasket
All brand new OEM gaskets and seals for top and bottom end
The block cleaned with a fresh hone, decked, and bored out .25 for oversized pistons.
As for the ECU, i went p28 Hondata s200.
You get what you pay for...
P73 Piston Rings
B16 Intake Manifold
ITR Crank pulley
Re: $$$price of ls/vtec conversion (ernald711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 »</TD></TR><TR><TD CLASS="quote">Mine was about $3100, that's not including labor cause we installed her ourselves. also the block was mine. i had to get everything else.
P73 Piston Rings
B16 Intake Manifold
ITR Crank pulley
how much hp you gettin to the wheels? how high are you revving daily? how does it feel?
P73 Piston Rings
B16 Intake Manifold
ITR Crank pulley
champLSinteg
Northern California (Sales)
13
05-01-2009 03:10 PM
