how do you remove a 98 civic door panel
Old 02-19-2005, 02:34 PM
WHiTETYPEs's Avatar
Default how do you remove a 98 civic door panel
^ Where are the screws located? Any clips etc....
WHiTETYPEs is offline
Old 02-19-2005, 03:27 PM
Unceasing Measure
Archidictus's Avatar
Default Re: how do you remove a 98 civic door panel (eK9RepreSenT)
Screw in upper right hand corner, screw in arm rest (trench), screw behind door handle, clips all around. Pop the clips then lift the door up over the window sill before tugging. Also, you need to get the window crank off.
Archidictus is offline
Old 02-19-2005, 03:31 PM
hatchling37's Avatar
Default Re: how do you remove a 98 civic door panel (Archidictus)
Also screws around the speaker
hatchling37 is offline
saxqtzk's Avatar
If you need pics I believe there's a link involving replacing the stock mirrors... and in it he goes into details on how to remove the door panels.
The instructions above pretty much explain everything though.
saxqtzk is offline
Old 02-20-2005, 11:19 AM
WHiTETYPEs's Avatar
Default Re: how do you remove a 98 civic door panel (hatchling37)
do the speaker covers just pop off?
Old 02-20-2005, 11:48 AM
tominos's Avatar
yes, they do.
tominos is offline
Old 02-20-2005, 11:54 AM
Judd's Avatar
Default Re: how do you remove a 98 civic door panel (tominos)
its easy to do
Judd is offline
Old 02-20-2005, 12:30 PM
jlacoy82's Avatar
Default Re: how do you remove a 98 civic door panel (Judd)
-Door handle - 1 screw
-Remove lower cover of arm rest - 2 screws
-Remove sail panel
-Remove speaker grill cover - 3 screws
-If you have power windows, roll them all the way down first.
Starting at the bottom of the door, pull out firmly, there are 6-8 clips holding the door on. Once you get it loose, unclip (if you have power options) the harnesses for the power windows and door locks and pop them back through the door.
Lift straight up on the panel and pop it off the lip from the window. Turn the door panel at about a 45 degree angle, with the front edge of it being lower and the rear end of it up in the air kind of in the window area and work the door handle through the panel. It helps if you pop the handle bar out of the first clip closest to the handle to give yourself more room to move the door panel. Get the door handle free and the door panel is free and clear, just pull it away now.
jlacoy82 is offline
Old 08-05-2012, 01:48 AM
RevrsOne's Avatar
-Remove sail panel
Nice write up, helped me out.
RevrsOne is offline
Old 08-05-2012, 08:00 AM
Former User's Avatar
Old thread closed.
Former User is offline
themurrell
02-21-2007 08:32 PM
DOHC hatchback
12-07-2005 04:56 PM
206civic
01-08-2005 11:43 AM
eddie1681
02-24-2003 10:33 PM
teg95
05-22-2002 01:16 PM
Quick Reply: how do you remove a 98 civic door panel
