| Welcome to Honda-Tech! | ||
#1 |
I want to locate my amp somewhere else in my car, I am wondering if it makes a difference if my ground wire is longer than the one provided originally by the wiring kit
If it does, ideally how long should my ground wire be ?
none |
#2 |
| Garage is empty, add now |
the only difference it will make is if its not long enough your amp wont turn on
#3 |
ideally you'd like to keep all the wiring as short as possible. where did you plan on mounting your amp that doesnt have a possible ground spot close by?
audiobahn [img]http://images.honda-tech.com/set1/smile/emthdown.gif[/img] Rear speakers [img]http://images.honda-tech.com/set1/smile/emthdown.gif[/img] Sony [img]http://images.honda-tech.com/set1/smile/emthdown.gif[/img] BOSE [img]http://images.honda-tech.com/set1/smile/emthdown.gif[/img] [quote=rochesterricer]99% of people wouldn't know a killer sound system if it walked up and smacked them in the face with a glass *****.[/quote] |
#4 | |
Relocating your sub shouldn't be an issue though - wherever it goes, you want to make the ground wire as short as possible (say ~ 18") and ensure you have a good solid connection to the chassis. Make sure you clean any paint off your ground point with some emery cloth and use a star washer to get good "bite" between the terminal & chassis. Bolt it solidly to the body with bolts, lock washers & nuts - no puny sheet metal screws! Best thing is to use a proper grounding terminal, like one from stinger or whoever takes your fancy. The wire gauge for the ground should be at least the same as that for the power. |
#5 |
thanks for all the advice guys, I had the amp mounted on the back of my box, i moved it so its sitting in a more vented area, i had to lengthen ground wire byabout 3 inches for it to fit, so i dont think i have affected it that much.
Thanks a lot
none |
| Tags |
| amp, be, bolts, car, difference, fit, ground, honda, insight, kit, lengthen, long, make, wire, wires |
