amp power wire for engine ground
Old Jun 23, 2006 | 05:05 PM
Jer'rome's Avatar
Default amp power wire for engine ground
is it possible to use this or will i melt? My engine ground is all rotten looking and i want to change it. thanks
Old Jun 23, 2006 | 06:02 PM
BlueCrxNC's Avatar
Default Re: amp power wire for engine ground (Crunk'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crunk’d &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to use this or will i melt? My engine ground is all rotten looking and i want to change it. thanks</TD></TR></TABLE>
"I'm melting... I'm MELLLTTTINGGG... aggg... gurgle gurgle. *STEAMING PILE OF GOO*"
You can use thicker wire as a ground, prefered actually.
Old Jun 24, 2006 | 08:03 AM
SuzukaBlueAP2's Avatar
Default Re: amp power wire for engine ground (BlueCrxNC)
If you want to make sure you have a really good ground...get a piece of 0 gage wire. 4 gag should do the trick though.
Old Jun 24, 2006 | 11:06 AM
Jer'rome's Avatar
Default Re: amp power wire for engine ground (SuzukaBlueAP2)
yeah its a 4 guage, but really thats not the issue. i noticed that they use steel braided wire unshielded for gound, the amp wire on the other hand has the plastic coating around it and with it being so close to the rad im wondering if it will melt.
Old Jun 25, 2006 | 08:07 AM
BlueCrxNC's Avatar
Nah, You're good. If it were right next to the exhaust manifold that'd be different.
Old Jun 25, 2006 | 05:46 PM
suspendedHatch's Avatar
Default Re: (BlueCrxNC)
8 gauge is fine for all your grounds except the one to the actual battery, which should be 4 gauge at least.
0 gauge is ridiculous even if the battery is in the trunk. Waste of money and added weight to the vehicle.
Old Jun 26, 2006 | 01:59 PM
Jer'rome's Avatar
thanks .. so far so good
MilanoCivic97
Audio / Security / Video
Apr 4, 2007 11:22 AM
JDM_lover03
Dec 15, 2004 12:22 PM
Kavehman
Oct 30, 2004 05:44 PM
JOMO_
Jul 3, 2003 11:22 AM
