[FAQ] What parts are interchangeable for all 92-00 Civics?
Old 07-17-2014, 12:06 PM
  #301
The Grumpiest
grumblemarc's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics?
Because coolness.
Old 10-13-2014, 06:02 PM
  #302
DOHCtR-V's Avatar
Any one know what rear view mirror I could use/swap in my EK.
It seems like all EK's suffer from loose rear view mirrors.
Mine moves around since my suspension is set to stiff, add the weight of an aftermarket mirror to the equation. ..
All the EK mirrors @ the pick & pull were all loose too.
I looked @ 7th gen civic mirrors, but they looked a bit different in the way they mount up.
5th gen connect by a button on the windshield.
Old 10-13-2014, 07:00 PM
  #303
Fish Twig
tony_2018's Avatar
I was actually looking at trying to get the 04 Acura TL w/autodim. Haven't gotten far because I don't have one to fool around with.
Old 01-05-2015, 09:20 PM
  #304
brickinthewall's Avatar
Default Re: (DOHC4life)
Originally Posted by eK9aT10pSi
your right, all the d series ex mani's are the same.
the radiators are the same [del sol is the best one though cause its dual core]
EXCEPT VX D15Z1 exhaust manifolds have o2 sensor in top of it.
VX D15Z1 intake manifolds have smaller openings also.
Old 01-26-2015, 01:33 PM
  #305
BSuns1's Avatar
What center consoles are interchangeable and where can I find a good one for cheap? I have a 94 civic ex without abs
Old 01-26-2015, 05:18 PM
  #306
orangecivichatch's Avatar
I did this mod. Never had a problem with it again.
6th Gen (6G) Honda Civic Rear View Mirror Vibration Fix
Old 02-17-2015, 02:12 PM
  #307
pvt_awol's Avatar
As someone mentioned earlier, the Del Sol Si rear brakes will bolt up to coupes, but the e-brake cables are not long enough on an EK chassis. I can confirm that this is also true for the 93-95 coupe chassis as well.
I'm going to try the same setup on an EG hatch though, before I get the thing up in the air and torn apart, can anyone confirm if the e-brake cables will be long enough for the hatch?
Old 08-27-2015, 07:18 AM
  #308
Stuominous's Avatar
I read every word of this dinosaur post.
Great info, need to know stuff.
I need to know what doors interchange with which. I have a 00 hatch with crank windows. The crank gear is cracked and needs replaced, and the door smells pretty freaking funky inside with the window. I'd rather replace all the interior components and clean it with bleach and nuclear compounds. If I can, can I swap the parts (except the glass) from other years??
I need:
Crank
Gear
Window rail
Everything
Thanks. Wish I had something to offer. All I did was put a D16Y8 tranny in the D16Y7 and swap out the O2 sensors with better ones. The stock Y7 O2 sensors kept setting off the CEL when I put a 2.5" pipe front to back. I replaced the stock header (D16Y7 has the Cat in the manifold) and swapped the whole system to an ex style exhaust. You will probably need new O2 sensors and wiring extensions if you want to do this - I did.
That's my contribution.
Old 08-28-2015, 06:36 AM
  #309
#1 Super Guy
94eg!'s Avatar
OEM Parts I've personally installed on a 94 CX hatchback:
- 93-95 EX 2-door door pockets added to my crank window doors
- S2000 interior door handles
- RSX Din pocket with door
- CRV P7J AC bracket (adapts stock compressor to B-series)
- GSR/ITR 24mm front sway bar
- ITR front LCAs (sway holes & special compliance bushing)
- GSR rear LCAs
- GSR 13mm rear sway bar
- ITR 22mm rear sway bar (requires ASR brace)
- DC Rear Discs
- DC2 2dr e-brake cables (required 1 chassis drain hole be used as a bolt hole)
- 93-95 EX 2dr or Del Sol VTEC non-abs front discs
- 93-95 EX 2dr or Del Sol VTEC non-abs master cylinder (7/8")
- DA 4040 proportioning valve (fits ok with DA bracket but switched to EG bracket for better fit)
- DC front strut tower bar
- DC front lower subframe brace
- Del Sol VTEC dual core half-radiator
- JDM EG6 Curved rear Gathers speakers
- JDM EG6 P30 Airbox lower half (has insulation blanket inside)
- EG2/EG6 P30 Airbox lid (has more volume and smooth-radius inlet)
- JDM NSX Type R Horn Button (works with aftermarket steering wheels)
- JDM ITR Recaro front seats
- JDM ITR Recaro DC2 front seat rails
- JDM ITR Shift boot
- JDM ITRx Pedal set (brake pedal has to be drilled off & bolted over US pedal)
- JDM ITR 97-spec B18C & transmission w/ OEM 32mm axles
- JDM ITR Gold shift linkage (no counter weight)
- JDM ITR Titanium weighted shift ****
- ITR DC2 rear seat upper halves (these bolt in but fit like crap, better reupholster stock ones)
Parts I have, but have yet to install:
- JDM EG6 power folding mirrors (require the mounting bases and passengers side glass to be swapped, and build your own wire harness).
- EK mirror mounted tweeters (I've seen photos of these in an EG, but it looks questionable)
Parts that fit EG I want to purchase:
- JDM ITR front LCA inner bushing (has a type-r part number we didn't get in the US)
- JDM ITR 98-spec rear UCAs (has a different tubular-steel design than standard stamped UCAs)
- ITR front lower sway mount bushings
- ITR rear sway bar end links
- ITR 3 engine torque mounts (front 2 requires modification to the frame rails on EG)
- US NSX Titanium key (actually made of Monel)
Old 08-29-2015, 05:04 PM
  #310
SidPM-EG6's Avatar
I didnt read all replies .. to many pages to go through
About B series trannys and driveshafts
All B series gearboxes (including swapping gear ratios , FD's and diff's etc) are interchangeable , y21 s4c s80 s9b...
Also driveshafts b16 fit in b18 and vice versa
Old 11-10-2015, 01:23 AM
  #311
Natalie Wright's Avatar
Will the coilovers from my 93 Civic fit on my 2000 Integra?
Old 11-10-2015, 01:33 AM
  #312
Stancetard Hate Monger
eghatch9295's Avatar
yup. this was DEFINITELY covered in here.
Old 01-17-2016, 08:58 AM
  #313
Vincent Whitman's Avatar
I have a 92 integra gs, I just bought it a couple days ago and like a dummy, I waited until now( it's snowing) to check the heat. It does not blow anything. I pulled the glove box to wiggle the relay and was hoping for an easy fix. There was nothing there. I know nothing about heating/cooling systems. I am not even sure how to check to see if everything is even in the car to make the heat work( blower motor, resistor, relay) could anyone please help me with pics and instructions on where to look an what I should look for? Also let me know if I am able to pull parts from civics and what civics can I pull from?
Old 02-11-2016, 06:57 PM
  #314
jjos's Avatar
can eg sedan door moldings fit on a ej6?
Old 02-21-2016, 01:01 AM
  #315
Kurbys's Avatar
What seatbelt buckle is compatible with an eg? Couldn't find that info here.
Old 02-22-2016, 12:45 PM
  #316
Premium Member
94 Civic Si's Avatar
This thread is $, thank you for creating!
Old 02-26-2016, 03:09 PM
  #317
Bipolarcivic's Avatar
will my header off my 94 civic coupe dx D16Z6 bolt directly on my 93 Del Sol SI D16Z6. i know it will bolt on the engine but will it hook up to the rest of the del sol's factory system ok or will i need to modify?
Old 02-27-2016, 09:41 AM
  #318
Hysterically Calm
TomCat39's Avatar
Goto Honda Parts at Honda Parts Now | Genuine OEM Honda Auto Parts and check part numbers of the header for the two cars. If they match, then zero issues. If they don't you will have to try it and see.
Old 02-28-2016, 08:43 AM
  #319
GDD's Resident Derp
W95civicEXcoupe's Avatar
How about cruise control stuff? How's that work?
Old 03-02-2016, 03:32 PM
  #320
Delited2meetU's Avatar
Think one of corner head bolts is stud
Old 03-22-2016, 03:58 PM
  #321
Steve Ashmore's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (kleanlscivic)
does this include integra LS back seats for 95 civic hatch?
Old 03-22-2016, 10:25 PM
  #322
yippee-ki-yay
eHMxhACk's Avatar
Is this a complete thought?
2dr (coupe) Integra, trim level doesn't matter, rear upper seat are a direct bolt in. The rear lower fits, but will have a gap between the upper and lower seats. Google it.
You can use the rear lower from the 4dr (sedan) Integra. It won't have the gap between the upper/lower seats, but it will on the forward corners because the stock Civic lower seat is rectangular and the Integra sedan isn't so much.
eH.
Old 03-23-2016, 08:41 AM
  #323
#1 Super Guy
94eg!'s Avatar
Just keep in mind that even though they "bolt in"....that doesn't mean they look good. I put ITR rear uppers in my 94 hatchback and they definitely don't fit as well as the original seats. There is about a 1 inch gap where they don't meet the rear cargo cover, and sides seem a little squished.
It would probably be a better investment to have your original seats custom upholstered.
Old 05-15-2016, 05:08 PM
  #324
95EG<3's Avatar
will a 1994 del sol door fit a 1995 honda civic dx?
Old 05-15-2016, 05:17 PM
  #325
95EG<3's Avatar
i have a 1995 honda civic dx and ik a person who is scrapping out a 1994 del sol which parts should i get from the del sol? price is not a problem. any help??
Quick Reply: [FAQ] What parts are interchangeable for all 92-00 Civics?
