My horn doesn't work, what to do?
Old 12-16-2001, 03:17 PM
FBP Si 2000's Avatar
Default My horn doesn't work, what to do?
Any ideas on what to do? Thanks in advance.
Old 12-16-2001, 03:21 PM
KJEG94's Avatar
Default Re: My horn doesn't work, what to do? (FBP Si 2000)
middle finger
Old 12-16-2001, 03:37 PM
nfiedler3's Avatar
Default Re: My horn doesn't work, what to do? (KJEG94)
megaphone when they can't see the middle finger
Old 12-16-2001, 04:12 PM
CanadaCivicSIR's Avatar
Check to see that the connector underneath the steering wheel, you can access it by popping the cover off, is connected. Next check to see if the wires are connected to your horn and there is no corrosion on them. BTW the horn is usually located between the bumper and your rad on the right hand side.
Old 12-16-2001, 04:51 PM
hydroflip's Avatar
Default Re: My horn doesn't work, what to do? (CanadaCivicSIR)
hahahah you guys are funny!
Old 12-16-2001, 07:50 PM
D Tranny Guru
Mista Bone's Avatar
can you hear the relay under the dash clicking??????
Old 12-16-2001, 08:04 PM
Default Re: My horn doesn't work, what to do? (Mista Bone)
Yeah, I can. I replaced the fuse also, but no luck.
Old 12-16-2001, 09:34 PM
D Tranny Guru
Mista Bone's Avatar
Check the horn itself or the connection to it. Likely the horn burned out.
Check for 12v at the horn connector when a buddy hits the button.
BTW you'll have to pull the bumper cover off to get to the horn.
Old 12-16-2001, 09:44 PM
Will do. I'm thinking the horn burned out, so I'll replace that and see if it works or not. Thanks for the help.
Old 12-16-2001, 10:06 PM
Yesman's Avatar
if its on your 2000 Si have it fixed under warrenty. that is unless you have already out run you warrenty.
Old 12-17-2001, 05:45 AM
ImportechPerformance's Avatar
Default Re: My horn doesn't work, what to do? (bishop)
if i were you i would fix it ....ha ha
Old 12-17-2001, 07:03 AM
Crazydave's Avatar
Default Re: My horn doesn't work, what to do? (MrPimpon)
Put a big truck horn on!
I hate those wimpy honda horns
Old 12-23-2001, 04:38 PM
b16b hatch's Avatar
replace the damn horn.
Old 12-23-2001, 07:25 PM
icyballa3's Avatar
Default Re: My horn doesn't work, what to do? (b16b hatch)
you might wanna check all of your fuses, im not sure about hondas, but i used to put in a lotta car stereos and if all of your fuses arent working, then sometimes they affect other electrical parts of the car..(ex in saturns, if the door chime fuse is blown, the raido wont work)
Old 12-23-2001, 07:54 PM
EG8R's Avatar
Default Re: My horn doesn't work, what to do? (icyballa3)
Get a Fiam air horn. Had one, it was great!!
LiL JoN
10
06-22-2010 09:22 PM
spintboy
01-12-2008 12:28 PM
tei344
11-09-2007 05:51 AM
BlueIntegraBoy
10-20-2006 05:38 PM
hardboiled egz
02-12-2003 06:20 PM
Quick Reply: My horn doesn't work, what to do?
