Old 10-10-2004, 10:09 PM   #1
brentmc79
brentmc79's Avatar
Send a message via AIM to brentmc79
Default DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!!
Be sure and view my previous thread... here
Well, I finally got off my ass and did it. It took me a while, but it wasn't all that hard.
Tools needed:
1/4", 3/8", and 1/2" drive ratchets
10mm & 12mm sockets (deep and regular)
assorted extensions
universal joint (may not be needed)
12mm wrench
screwdrivers (phillips and flathead)
pliers
drill and bits
8mm x 1.25 tap
wire stripper
electrical tape
Parts/materials needed:
D16Y8 intake manifold (manual or auto, but I used an auto)
D16Z6 intake and throttle body gaskets
D16Y8 injector seals
12" of 5/32" (4mm) ID vacuum tubing
Y8 fuel rail (although I used a Z6 rail)
Ok, so let's get started. Here's what mine looked like when I started.
1. Disconnect the negative battery terminal (duh)
2. Disconnect the intake
3. Disconnect the throttle cable
4. Drain the coolant by removing the plug at the base of the radiator, and be sure to remove the radiator cap to make it go a little faster
5. Remove the throttle body, there's 2 bolts and two nuts, all 12mm. Also, remove the two coolant lines just below the TB, where the manifold meets the head. Remove the IACV held on by two 12mm bolts and the other sensor (not sure what it's called) held by two phillips screws, and unclip the sensor on the bottom of the manifold.
6. Remove the injector clips from the injectors. Use a small flathead screwdriver, but be careful not to lose the clips. Remove the two 10mm nuts to release the injector harness. Place a rag under the fuel filter and then remove the hose that goes to the fuel rail, but first be sure to release fuel pressure by removing the gas cap. Then remove the three 10mm nuts holding the fuel rail down, the vacuum line running from the fpr to the manifold, and remove the rail and injectors. Be careful not to touch the tips of the injectors.
7. Remove the two 12mm bolts from the brace on the underside if the intake manifold. If you're lucky, you can do this without getting under the car, but it's a tight fit.
8. Remove the seven 12mm nuts holding the manifold to the cylinder head. I had to get a universal joint to get to the middle nut on the underside.
9. Slide the manifold off of the studs and lift it up enough to remove the hose connected to the oil cooler, then totally remove the manifold.
10. Now let's swap stuff over from the Z6 mani to the Y8 mani. When looking at the two manifold, you'll notice that there are several things different about them. For one, the TB studs are in opposite locations. This shouldn't matter, although I switched them around anyway.
11. Go ahead and mount the injectors and fuel rail on the Y8 manifold. It would be easiest to use a Y8 fuel rail rather than a Z6 rail cuz they bolt up differently. Unfortunately, I didn't have a Y8 rail, so I just drilled hole in the Z6 rail so I could use it. It'd also be in you best interest to use new injector seals cuz the Y8 and Z6 seals are different thicknesses, but I didn't and it hasn't leaked at all.
(I forgot to take a pic... doh!)
12. Remove the check valve that was connected to the oil cooler from the Z6 manifold. Reconnect the two hoses and the check valve, and then attach it back to the oil cooler. Also, go ahead and put your new manifold gasket on. Make sure you removed ALL of the old gasket first, as it may not seal properly if you don't.
13. Go ahead an remove the manifold brace from the block entirely, as it won't work with the Y8 mani. Mount the Y8 manifold on the head, using the seven 12mm nuts to hold it in place. Run the hose with the check valve throught hole between the 2nd and 3rd runners, and connect it to one of the two larger nipples on the plenum. The other one will be blocked off.
14. Connect the fpr to the rail. You will need to cut a longer piece of vacuum tubing to run from the fpr to the nipple near the throttle body. I think I used about 10-12".
15. Trim the brake booster line and attach it to the large nipple on the back of the plenum. Also, reattach the small vacuum line to the nipple on the bottom rear of the manifold. There's nowhere to attach this sensor/valve/whatever to the manifold, so either zip tie it off somewhere, or just do like I did and use the hose bracket that bolts to the IACV to hold it in place. Don't worry about the connector that's left over. We'll take care of that later.
16. Bolt up the throttle body and IACV.
17. Reconnect the coolant lines. You can use just one of the hoses instead of the two hoses with the hard line in between.
18. Reconnect the fuel line. Make sure you didn't lose either of the little metal washers.
19. Now attach the throttle cable bracket. As you can see here, the Z6 and Y8 brackets are different. The angle of the Y8 bracket is more appropriate, but the cable is a little short, so you have to mount it using only one of the holes.
20. Now for the left over sensor from the back of the Z6 manifold. It's supposed to be mounted in the manifold (obviously), but I didn't feel like dirlling and tapping more holes in the manifold, so I decided to just mount it in the intake pipe. I just drilled three quick holes. No tapping was necessary.
21. In order to mount it in the intake pipe, you must also extend the connector about 18-24". I wrapped the two wires in electrical tape just to make it a little cleaner looking.
There ya go
22. Reconnect your intake, refill your coolant, being sure to use the air bleed bolt to remove all air bubbles. Now fire it up and see how she runs!
Well, there ya go. Some people say that you can't tell a difference on the butt dyno, but I felt like it was definitely stronger in the 5-7k rpm range. :thumbs_up Plus, it looks pretty sweet with the fat black manifold.
Whew! I don't think I've ever written a post this long before.
Modified by brentmc79 at 7:19 AM 10/11/2004
I'm a freakin Mazda man now...
03 Mazda P5 <- waitin for the speed3
06 Mazda 5 <- grocery getter
94 <FONT COLOR="red">Civic</FONT> EX coupe - totalled
95 Accord LX - sold
89 CRX DX - DOHC ZC, i/h/e, blah, blah, blah... sold http://images.honda-tech.com/set1/smile/emsad.gif
96 Integra LS - sold
93 Civic 4dr - sold
89 CRX dx - sold
87 Civic - dead
brentmc79 is offline Report Post   Reply With Quote
Old 10-10-2004, 10:48 PM   #2
Br1anPham
Br1anPham's Avatar
Send a message via AIM to Br1anPham
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (brentmc79)
nice, i have a black IM too
should have put the IAT sensor on the bottom of your intake.
for you and your fat Y8 manifold.
Br1anPham is offline Report Post   Reply With Quote
Old 01-23-2005, 03:19 AM   #3
hondainspired
hondainspired's Avatar
Send a message via AIM to hondainspired
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (Br1anPham)
in all honesty is it worth the swap... i have a complete y8 head, mani, dizzy, rail and injectors ready to swap... all i wanna use is the mani, the cam and cam gear would it be worth my time and lil bit of money...
JAY
01 Audi TTR- DAILY
88 FC + 13B-RE= TRACK
hondainspired is offline Report Post   Reply With Quote
Old 01-23-2005, 05:09 AM   #4
james p.
james p.'s Avatar
amazing work! excellent write up!
eh6 /// ej9
dSoc
james p. is offline Report Post   Reply With Quote
Old 01-23-2005, 08:21 AM   #5
XxSOHCDriVerxX
XxSOHCDriVerxX's Avatar
Send a message via AIM to XxSOHCDriVerxX
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (james p.)
nice write up...imma do that too real soon.
I MISS THE OLD HONDA-TECH..... http://images.honda-tech.com/set1/smile/emsad.gif
Phaze 2
keeping it old skool....71 corolla son!!!!
1995 Civic EX W/ABS Turbo = GONE!!!
1971 Corolla = Weekend queen!!!
2005 TC = Daily driver!!!
XxSOHCDriVerxX is offline Report Post   Reply With Quote
Old 01-23-2005, 08:31 AM   #6
Dr. D-Series
Dr. D-Series's Avatar
Since when does a D16 have an oil cooler ?
And your feeling the exact opposite of what you should be. The big plenum and THINNER runners will give you more low to midrange torque.
Your butt dyno is out of tune.
Eagle/Vitara Z6 436 whp 340 tq 10.452 @132.3, 1.625 60 ft. - Current. Xenocron Tuned.
Eagle/Vitara Y7 279 whp 210 tq 11.200 @124.5, 1.68 60 ft.
D15 Block / Y7 202 whp 160 tq 12.1 @112 , 1.70 60 ft.
Dr. D-Series is offline Report Post   Reply With Quote
Old 01-23-2005, 08:33 AM   #7
huntarrr
huntarrr's Avatar
Send a message via AIM to huntarrr
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (XxSOHCDriVerxX)
Nice write-up! I was always discouraged to take off the intake mani because of the 12mm bolts on the underside... Never felt like trying to get to them, but it doesn't look TOO hard... I guess I'll give it a try.
[DC Squad Member # 0501]
huntarrr is offline Report Post   Reply With Quote
Old 01-23-2005, 08:56 AM   #8
fishnfst
fishnfst's Avatar
To make it even easier you can clamp off the coolant lines and the fuel ilnes then you don't have to bleed your cooling system and you won't lose any fuel...
http://www.Spoolinperformance.com My welder of choice....Phil is the man
http://www.pdqmotorsports.net for all my braking needs...... Big thumbs up to Mike...
fishnfst is offline Report Post   Reply With Quote
Old 01-23-2005, 09:23 AM   #9
sockvtec
sockvtec's Avatar
Send a message via AIM to sockvtec
great write up, ima use this when i decide to do that swap...thanks man
I <FONT COLOR="red">&#9829</FONT> my Honda 1992 EH3 - stock motor w/ 286k
R.I.P
damn people who dont have insurance and total your car!!
vouches in bio http://images.honda-tech.com/set1/smile/emsmile.gif
<FONT SIZE="1"><FONT COLOR="d60000">ROLL TIDE!!</FONT></FONT>
sockvtec is offline Report Post   Reply With Quote
Old 01-24-2006, 10:38 PM   #10
Bense
Moderator
Bense's Avatar
Send a message via ICQ to Bense Send a message via AIM to Bense Send a message via MSN to Bense Send a message via Yahoo to Bense Send a message via Skype™ to Bense
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (sockvtec)
how did you remove this from the z6 intake manifold?
Bense is offline Report Post   Reply With Quote
Old 01-24-2006, 10:54 PM   #11
Mwsol
1996 Honda Del Sol
Mwsol's Avatar
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (Bense)
I honestly dont know why you did this. Please explain. I'm quite interested.
dSoc # 53 - Mwsol
Mwsol is offline Report Post   Reply With Quote
Old 01-24-2006, 11:17 PM   #12
Voyage34
Voyage34's Avatar
Send a message via AIM to Voyage34
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (Mwsol)
great writeup! im already runnign the y8 IM, the black looks sick as hell, i think i might paint mine.
Voyage34 is offline Report Post   Reply With Quote
Old 01-25-2006, 12:12 AM   #13
tsdenny
tsdenny's Avatar
excellent write up
this will be handy soon
WTB
for my 95 civic ex rear lip, amber corners, MR hood, MR trunk, oem fog light coupe,,
tsdenny is offline Report Post   Reply With Quote
Old 01-27-2006, 08:52 PM   #14
EGDominator
Guest
Posts: n/a
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (void_accord)
Voyage34 is a dumbass. Don't listen to his nonsense.
Old 01-29-2006, 12:07 PM   #15
Voyage34
Voyage34's Avatar
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (EGDominator)
what nonsense? if you want to shittalk or yell at me do it through PM so we dont have to waste any more of anyone elses time.
there are a few differenced between the intake manis. the z6 has shorter/fatter runners which would give it better top end, the y8 has a huge plenum for quicker throttle response and somewhat beter midrange. depending on the performance goals each one has its pros and cons.
Old 01-29-2006, 01:33 PM   #16
Mwsol
1996 Honda Del Sol
Mwsol's Avatar
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (Voyage34)
I know there is a difference, but I happen to know that a z6 is better for N/A, and a y8 mani is better for boost. As far as time was concerned you have wasted alot of it, but whatever makes you feel good for gaining very little horsepower. Next time you end up doing something like this, get some dyno graphs and prove me wrong. Butt dynos do not count.
dSoc # 53 - Mwsol
Old 01-29-2006, 03:49 PM   #17
quicksilver1689
i ♥ snails
quicksilver1689's Avatar
Send a message via AIM to quicksilver1689
Mwsol, shut up dude no one cares about your opinion you dont know shit and dont flame
him you asshole.
Good job on the manifold swap. Looks good. I remember the days of d16's.
it was a fuel used 10 years ago for go kart engines and quite illegally used into rally and drag racing. No longer exist at today.
quicksilver1689 is offline Report Post   Reply With Quote
Old 02-02-2006, 02:26 PM   #18
EGDominator
Guest
Posts: n/a
Voyage34 has a shitty as car. And I ask a simple question, and get a retaliated, negative response back from this dickhead. Unecessary slaughtering of a simple question demands a response I bet my car would molest yours in a race. ASSHOLE! Sorry for disrupting this top, but someone had to stand up and say no to his smart ass remarks. I hope one day I see you on the road driving your shit mobile, and me laughing after I desecrate you with my 1994 Honda Civic HB. So shit on that, ****er.
Old 02-02-2006, 02:57 PM   #19
Archidictus
Unceasing Measure
1998 Oldsmobile Intrigue
Archidictus's Avatar
Send a message via AIM to Archidictus
him you asshole.
Who the expletive are you people? Go back to masturbating to free pr0n and get off my website.
Jesus Christ. Stop ruining threads with your petty bullshit or I'm going to ban you.
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline Report Post   Reply With Quote
Old 02-03-2006, 09:12 AM   #20
nerdsports
nerdsports's Avatar
Send a message via AIM to nerdsports
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (Archidictus)
cant believe this thread was brought up from a year ago and then some asshats come in talking garbage.
this is a good thread, its about time i change my puny OBD1 DX manifold on my boosted D16. Just 1 thing i found wrong...
that 'oil cooler' is actually the PCV oil catchcan and that check valve is the actual PCV valve. I got confused w/ all that oil cooler stuff hehe.
Good thread
nerdsports is offline Report Post   Reply With Quote
Old 02-03-2006, 09:19 AM   #21
Bense
Moderator
Bense's Avatar
Default Re: DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! (nerdsports)
I brought the thread back from the dead because I asked a technical question while doing a swap.
You know how it is, working at night outside in the cold, getting dirty and not wanting to spend 20 minutes searching and/or creating a thread
Old 02-03-2006, 10:25 AM   #22
nerdsports
nerdsports's Avatar
wasnt talking about you. ive brought some threads back up myself, but the asshats after you (the trial users) started talking nonsense in a thread w/ useful info.
hope you got your ? answered.
Old 02-06-2006, 03:29 PM   #23
95gainfla
95gainfla's Avatar
Send a message via AIM to 95gainfla
what HG do you use?
95gainfla is offline Report Post   Reply With Quote
Old 02-06-2006, 03:33 PM   #24
Bense
Moderator
Bense's Avatar
Default Re: (95gainfla)
head gasket?
doh, no need to change the head gasket on the intake manifold
Old 02-06-2006, 03:42 PM   #25
EJ1 wilcox
EJ1 wilcox's Avatar
Originally Posted by 95gainfla
what HG do you use?
He didn't replace the head gasket.
You can use a d16y8 head gasket because they are cheaper than the z6 ones!
I've never seen a d16z6 with an oil cooler before.
EJ1 wilcox is offline Report Post   Reply With Quote
Bookmarks
01, 96, bolts, civic, d16y8, d16z6, intake, manifold, pressure, removing, swap, vacuum, wire, y8, z6, zc
