Vented Valve Cover Post up some pics!
#26
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dro330 »</TD></TR><TR><TD CLASS="quote">i never really found out the importance to venting the valve cover. drop oil pressure? cleaner oil? dunno! i really only see b16s and b18s with them. I have an h22 prelude, would it be useful to have one. other than that love the setups.</TD></TR></TABLE>
It's used to vent blowby gasses that come from the engine. This is all related to ring gaps. If you vent the pressure of these gasses power is free'd up.
That's the plain and simple approach.
![](https://honda-tech.com/forums/images/smilies/emsmilep.gif)
#28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">
Couldnt put it into any more simple terms.
![](https://honda-tech.com/forums/images/smilies/emthup.gif)
#31
I dunno what the deal is with more than one...?? Come on now! Defenitely not necessary. No way any street motors need 2...posibbly on full race engines, but then youd have a vaccuum pump. Seems a little rediculous to me.
Kyle
Kyle
#32
noticed that the pics posted are the vtec covers. is there any difference with location for LS covers? difference in baffles or anything? aka am i safe to put mine on the front of the valve cover (its a b18a1 cover style)
#33
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueoval557 »</TD></TR><TR><TD CLASS="quote">I dunno what the deal is with more than one...?? Come on now! Defenitely not necessary. No way any street motors need 2...posibbly on full race engines, but then youd have a vaccuum pump. Seems a little rediculous to me.
Kyle</TD></TR></TABLE>
it's all about bandwagon and bling factor.
#34
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lodo »</TD></TR><TR><TD CLASS="quote">
it's all about bandwagon and bling factor.</TD></TR></TABLE>
Actually, the goal it to get as much pressure out of the motor as possible. 2 will get pressure out faster then 1.
#36
1 Post
15 HP on the dyno was worth it for me
#40
ok i see that u have two fittings running from the valve cover to the catch can, but where do u have the other two fittings on the bottom of the catch can running to?
#41
ok i see that u have two fittings running from the valve cover to the catch can, but where do u have the other two fittings on the bottom of the catch can running to?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">![](https://honda-tech.com/forums/images/smilies/emsmile.gif)
![](http://sebastianstewart.net/piping1.jpg)
#45
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">It's used to vent blowby gasses that come from the engine. This is all related to ring gaps. If you vent the pressure of these gasses power is free'd up.
im more curious why people leave these open to free air, and dont have a baffled closed setup that has vacuum pulled from the intake. if you want to get rid of positive pressure in the head, pulling it out would be more effective than just venting it.
also, do the endyn type, back of the block setups vent? or does vacuum get hooked to them? or are they just drain backs...?
#46
With the Endyn setup you have the option of a closed PCV can or a vented/filtered can.
You're right though. Pulling a vac on the head is the best way to evecuate crankcase pressures. Since it is expensive this is the next best thing. There are no bad side effects to running a vented catch can.
#47
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind-Fashion »</TD></TR><TR><TD CLASS="quote">![](http://a837.ac-images.myspacecdn.com/images01/8/l_eb320aa99f07b03a77a7977d3813e244.jpg)
4 out of the valve cover and 2 in the back of the block for the drainback that come from the bottom of the catch can</TD></TR></TABLE>
Sick!!
Sick!!
#48
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaruss »</TD></TR><TR><TD CLASS="quote">Anyone know the part number for the barbed plugs from honda that go in the back of the block to vent there also?</TD></TR></TABLE>
#49
how is running a closed system to your manifold expensive?
or were you talking about the endyn kit?
and i know no bad effects, but possibly no good ones in some cases. think about that.
#50
Thank you kindly!
Thank you kindly!
