Civic Type R P0420 code
Old 08-30-2014, 07:36 AM
Housey's Avatar
Default Civic Type R P0420 code
Have a civic type r 2002 135k on the clock. Fitted an aftermarket cat, and 2 new sensors cleared the code. Now after 3 days the code has unfortunately returned which has gave me a real headache.
When the cat was installed plugged in a laptop with diag software which again showed mirrored fluctuating signals in both o2 sensors in closed loop mode.
Any Ideas out there
Old 09-01-2014, 07:25 AM
SickSi99's Avatar
Default Re: Civic Type R P0420 code
I'd be willing to guess the aftermarket cat is what's causing your ECU to freak out and show a deficiency in your O2 sensor. You might need a defouler to move it away from the stream a little bit.
Old 04-03-2015, 02:04 AM
Housey's Avatar
Yes I used an o2 sensor spacer right angled, code no longer appears and car appears to run a lot better.
Cheers
YaBoiTHiZZ
12
03-28-2012 08:10 PM
impr323
06-21-2005 05:29 PM
danteisme
03-16-2005 07:01 AM
py1188
05-17-2004 06:37 AM
Quick Reply: Civic Type R P0420 code
