What could be causing my Code 67?
Old May 15, 2004 | 05:30 PM
py1188's Avatar
Default what could be causing my code 67
Alright, now I'm just plain upset. I have gotten a code 67 again, and I have no idea where its coming from. What are all the possibilities? I originally anticiptaed it was the secondary O2 sensor, but I put it on my buddies b16 to see if it would throw a code and....well it didn't. My next guess was that it was my carsound, so over the winter I replaced the Carsound, and thought everything was okay. The car even passed emissions in the meantime. Now today, on my way back from our Chicago ITR bbq, the damn light came back on, and wouldn't you guess it, another code 67.
My question is what the hell else could be causing this damn CEL
Also, BTW, I am now using a secondary O2 off a 2000 Civic SI. Could this be causing it?
Old May 15, 2004 | 05:57 PM
mstyper's Avatar
Default Re: what could be causing my code 67 (py1188)
it is your 2nd o2 senser ther are two was to fix it. New o2 or cat. Next one well I would tell you but on HT I never know who is out there.
Old May 15, 2004 | 06:16 PM
Chris N's Avatar
Default Re: what could be causing my code 67 (mstyper)
Same problem. My cat on other cars has no issues. I think it is the o2 wiring harness/plug or the o2 sensor itself.
Old May 15, 2004 | 06:26 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstyper &raquo;</TD></TR><TR><TD CLASS="quote">it is your 2nd o2 senser ther are two was to fix it. New o2 or cat. Next one well I would tell you but on HT I never know who is out there.</TD></TR></TABLE>
Old May 15, 2004 | 07:35 PM
96dc2's Avatar
Using that O2 sensor is fine.
You have the Hytech header and exhaust right? Maybe your cat is too far and not getting "hot" enough to heat up the sensor? Or maybe the Carsound got bad already?
Old May 15, 2004 | 09:33 PM
py1188's Avatar
Default Re: what could be causing my code 67 (96dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Using that O2 sensor is fine.
QUOTE]
Thats what I figured
[QUOTE=96dc2]Using that O2 sensor is fine.
You have the Hytech header and exhaust right? Maybe your cat is too far and not getting "hot" enough to heat up the sensor? Or maybe the Carsound got bad already?</TD></TR></TABLE>
The Carsound actually has two bungs. I am using the front bung before the catalyst material. Should I extend the wiring and use the bung behind the catalyst?
Old May 15, 2004 | 10:47 PM
TypeRP2's Avatar
You need to torque the sensor properly. Outside air will kill it after couple months.
Old May 16, 2004 | 08:07 AM
py1188's Avatar
Default Re: what could be causing my code 67 (TypeRP2)
This car has only been drive about 40 miles or so with the new cat, and its torqed down fine.
Can anyone answer the question of whether or not I should try the other bung?
Old May 16, 2004 | 08:47 AM
BudMan's Avatar
I always get the same code after ~3 months of a new cat (Random Technology). I've finally concluded that there is just too much fuel being thrown in from the stock computer which blows the cat coupled with the fact it just doesn't get hot enough to burn any excess.
That said - when I'm on the track...it NEVER throws that code. Only when I go to get gas & I'm driving easy. The Helms manual says that the code must see the condition 3 times before displaying the code. To bad I don't have a palm pilot - I found software that would allow me to reset w/o pulling the fuse Or I could just get a hondata & tune the whole freak'n fuel curve
Old May 16, 2004 | 09:58 AM
py1188's Avatar
Default Re: what could be causing my code 67 (BudMan)
Yeah I'm completely awestruck. I know I could be running a bit rich, but Ive had the cat on the car for a total of 40 miles. Its just ridiculous.
I may try and extend the wiring in order to get it behind the catalyst material. Where is the sensor placed on an OEM unit?
Old May 16, 2004 | 10:38 AM
R134's Avatar
I think it's because the carsound isn't as efficient as the stock one so it throws a code. Mine did the same thing. I tried the tin foil trick and leaving it out of the cat, neither worked.
I ended up doing the o2 sensor mod:
https://honda-tech.com/zerothread?id=221347
Here's how it looked when i was done, note the wire colors are off since i had to extend my wires since i have a long header and didn't have the appropriate color wires. It's been working fine without a CEL for quite a while now.
Old May 16, 2004 | 02:16 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">
The Carsound actually has two bungs. I am using the front bung before the catalyst material. Should I extend the wiring and use the bung behind the catalyst?</TD></TR></TABLE>
The secondary sensor should be placed AFTER the catalyst material. If it's in front, then it's just reading the same as the primary sensor.
Old May 16, 2004 | 03:17 PM
py1188's Avatar
So would you say that could be causing the code??
Old May 16, 2004 | 03:51 PM
96dc2's Avatar
It's very probably cause.
Old May 17, 2004 | 06:37 AM
py1188's Avatar
I'll try extending the wiring to get to the other bung and I'll see if that works out
DVS Luder
Feb 19, 2006 09:31 AM
EF8IGHT
Jan 10, 2006 02:52 PM
impr323
Jun 21, 2005 05:29 PM
civicsicko
Jul 16, 2004 10:10 PM
EG2 SiR
Mar 4, 2004 10:35 AM
