OE motor mounts
Old 07-27-2014, 05:06 PM
94 accord typeR's Avatar
Default OE motor mounts
i want to get OE motor mounts. im thinking about Westar or Anchor. i watched anchors video where the mount held up under 2300lbs of pressure. price is about the same warranty is the same.
any horror stories?
any good personal expirences?
im looking to get all 4 mounts (3 engine 1 trans) and i want them all to match mfgs.
DEA doesnt have much info. im assuming Honda requires mounts to hold under 1200lbs of pressure or maybe industry standard
Old 07-27-2014, 06:19 PM
He knows where you live!
TheMuffinMan's Avatar
Default Re: OE motor mounts
If you're getting aftermarket mounts, they aren't OEM and shouldn't refer to them as that.
TAS Auto aftermarket replacements work just fine, I used them on my '96 and '97
Old 07-27-2014, 06:43 PM
kevinhughes13's Avatar
If you purchase the anchor mounts at advancedauto order online and pick up at your local store use code TRT30 never expires and will save you a bit.
Old 07-27-2014, 06:59 PM
yeah in store prices are quite high. rockauto has them for $110 ish shipped for all 4 LMAO. i watched a youtube vid on the rear mount looks kinda difficult
OE=Original Equipment where Hasport etc would be custom mounts right?
OEM= OE Manufacturer Honda, Toyota, DODGE, Ford etc
Old 07-27-2014, 11:00 PM
jmanuel's Avatar
I bought anchor the other day the quality looked pretty poor and read some reviews on how they give out over a few months so ppl would have to change em out every once and a while since they had lifetime warranty. Took them back.
Old 07-27-2014, 11:01 PM
jmanuel's Avatar
Also anyone have any input on oem honda mounts? Is there a difference buying from town dealership or online like majestic honda? Is it legit honda?
Old 07-28-2014, 06:25 AM
http://www.bimmerzone.com/category/T...ricks_OEM.html
OE (Original Equipment or Genuine BMW)
These are the parts that you get EXACTLY as if you are walking up to an authorized dealership and buying a part at the parts counter. (Example: Oxygen Sensor BMW Part # 11 78 1 735 499). These parts usually come in BMW marked packaging.
OEM (Original Equipment Manufacturer)
OEM parts are parts that come from the same factory that makes your Original BMW parts, but they are boxed in their respective brands. (Example: Oxygen Sensor BOSCH Part #13231, which cross references to: BMW Part # 11 78 1 735 499). These parts are sold directly from the manufacturer to the suppliers or retailers and not through the BMW Dealer network, and usually means savings for the end consumer while still having the same OEM standards that the vehicle manufacturer specified.
You are referring to aftermarket parts. Hasport would be 'aftermarket' or third-party as well.
Anchor and Westar are not to my knowledge the OEM's for Honda.
Old 07-28-2014, 06:26 AM
If by 'town dealership' you mean _______ Honda, your local Honda dealership, then there is no difference between their parts and Majestic.
Look into TAS Auto, I used their aftermarket mounts without any issues.
Old 07-28-2014, 09:01 AM
You = Troll
Old 07-28-2014, 09:22 AM
thanks for the insight
Majestic Honda is a Honda Dealership. they have really low prices and can beat most In-Town Dealers. even when u add in shipping the Majestic prices should be less, unless u need the parts immediately.
I was hoping to avoid $200 dollar mounts but maybe not. cant seem to dodge them
Old 07-28-2014, 09:41 AM
You = Troll
Correcting someone posting incorrect info isn't trolling.
And to add to that, I suggested a reputable company (TAS Auto) that's listed in the Accord FAQ that has both OEM and aftermarket parts that are of good quality.
Old 07-28-2014, 09:58 AM
anyone else?
Old 07-28-2014, 01:27 PM
just got back for Camp Crystal Lake (oooo the Horror)
guess the only option Everyone agrees on is.....
Poly inserts. LOL. sound like a PITA but $600 for 4 mounts
and still no trans mount or side mount insert
Old 07-29-2014, 02:19 PM
Use urethane window weld in the OEM mounts, most hardware stores have it and it will behave very close to poly inserts.
Old 07-29-2014, 04:10 PM
jmanuel's Avatar
I've purchased from majestic honda before everything was okay but three tube seals ibought from them gave out after like 1month and got oil in all my spark plug tubes. Pita. Just being paranoid bt if they're a legit honda dealership why so much cheaper?
Old 07-29-2014, 05:18 PM
Majestic sells things at near dealer cost. The dealership marks up everything. Like do you really think a single plastic bumper clip should cost $5? Of course not. The dealer buys them for $2 or so then adds on $3 for their cut.
Anything you purchase from Majestic should come in an OEM Honda package with an OEM Honda part number. Generally, if you're purchasing smaller items you're better buying them local, Majestic adds on a processing/packaging fee that can make those little clips pricey.
Old 07-29-2014, 05:28 PM
jmanuel's Avatar
I see.. Makes sense tho. Already placed order with my dealership only 14$ more than majestic. I'll probably order from majestic next tho just to re try them out.
Old 07-29-2014, 06:35 PM
yeah i saw that on youtube and on Acuraforum
fordfocusforum says only use OEM (motorcraft) @ $115
mustangforum says poly insert (Energy suspension or Prothane) and in fact the Anchor mount had a few engines sitting so low they caused major engine damage which anchor wouldn't even acknowledge they just refered them to the store for lifetime warranty exchange
nissanforum says poly insert (ES or Prothane)
saturn forum says OEM (GM) no frowny face mount =(
Honda OEM mounts from Majestic are around $600 for all 4 or polyurethane front and rear mount and OEM side and trans mount for around $300
decisions decisions
Old 07-30-2014, 06:49 PM
chrisnick's Avatar
esp.net mounts.
Old 07-31-2014, 11:26 AM
AutohausAZ-Mike's Avatar
Hi,
We carry a few different brands of motor mounts for the Honda Accord.
All motor mounts come with a one year warranty.
Here is the link for the mounts:
AutohausAZ - Motor mounts
Disclaimer: Make sure to verify the year and model of the vehicle to make
sure proper fitment.
D16SohcVtec
08-12-2008 08:03 AM
clem kevin
05-01-2008 06:57 PM
NAmodified
10-16-2007 08:35 AM
Bbasso
03-04-2005 05:48 PM
CeeAreEx90
15
01-07-2005 03:55 PM
Quick Reply: OE motor mounts
