La Gallina Industries / Humble Performance SFWD Turbo K Project
#101
Re: La Gallina Industries / Humble Performance SFWD Turbo K Project
With a 2.4 and the backhousing I had on the 67mm it was a beast, even on wastegate spring. There was not a lot of lag at all. I had the 6765 with the vband inlet .82 exhaust housing. Put it this way, it went 110mph in the 1/8th on wastegate spring and pump 93 in my car. I had a tial 60mm and wastegate spring pressure was roughly 15psi on my setup.
#104
I drove mine not too long ago, definitely need to either get a bigger WG or a different manifold :-/
BEAST!!!
#105
#106
LoL Its as reliable as your tune and parts/fuel.
OP: NICE PROGRESS!!!
Why are you needing another manifold?
#107
Some have good luck with stock transmissions and get many passes out of them on higher power levels. I didn't and called it quits on that setup, not to mention I have another project that I really want to finish up. I sold the manifold, turbo, and shortblock. But for the limited driving I did with the car and the passes I made on the track, it was really fun on low boost and was easily a low 10sec and maybe a high 9 sec car on a really good day.
#108
i'm running a 10psi spring and i cannot boost less than 18psi for some reason, it could either be horrible boost creep or maybe an issue in the boost parameters of some sort. So while we try and figure out if it's the parameters, i've put it up for sale just in case it's the manifold.
#110
#112
If i could get it at 10psi i'd be happy lol, i know that 10psi would still spin the tires a bit but it's a hell of a lot better than 18 hahaha
#113
Had a 60mm gate on mine, I don't know what spring was in the gate because I never looked :/. But, I was warned by a couple people that have really fast cars that my car may act like their race cars. They said no matter what spring they put into the gate their setup was still going to run around 20psi worth of boost on wastegate spring. They were exactly right, my car would run roughly 17psi on the spring and would not go lower. I was advised to maybe put a full exhaust on the car to choke it up a little and that could possibly help since it was a street car, but I never did. At first I was worried that 17psi in 1-2nd gear would be too much on the track, but it wasn't really. At least not for my car on a decent track. Took it to a garbage track twice and it would really blow the tires off on the hit, but it would start hooking 2nd.
#114
#115
There are certainly ways to do it, no doubt about that. You have more room in your car and a wastegate or manifold change might do it for you. I had limited space to work with and didn't want to really try to correct it on my car.
#116
I friend of mine is running a 6266 with the same manifold and tial 44mm gate if i'm not mistaken, and is running looooow boost, it's certainly possible. Our builds are slightly different but i doubt that those differences account for a 12-14psi difference in boost levels when going off the gate... it has to be something in the calibration
#117
By the way I did all this on Friday for my NHRA License passes. This is also pretty weird but I am running Weld 13x9 rims with M&H 24.5 x 8.5 slicks. The lower the tire pressure the worse my 60fts. I was telling everyone that the less tire pressure the worse it was but everyone was like no way. So this is how the passes went, first pass was on 7 psi of tire pressure, had a 1.64 60ft. The next two passes were at 6 psi and my 60 went into 1.7's and 1.8's. My 4th pass I said let's put air back in so we ran 8 psi and my 60 foot was a 1.61. My 5th pass we added another .5 so I was at 8.5 psi of tire pressure and the next 60ft was 1.58.
Now if I put a small red gate spring in which is one step below the green I could have probably got down to 10 psi. Then the more air in the slicks my 60ft. went down. I am sure everyone has different things that work for them but this is what worked for me. Got a 10.0 pass
#118
Yeah every time I was at the track it would be right around 17 psi with the Large Yellow spring which is an 8.7 psi spring. We changed the spring with the small green which is a 5.8 psi spring and was able to get it down to 12 psi in first.
Jacyp7719
12-28-2018 06:39 PM
Jay7
10-09-2006 08:10 AM
Jay7
Northeast (Sales)
09-29-2006 12:56 AM
