How much does your race EG hatch weigh?
Old 03-17-2014, 03:40 AM
  #76
Sccacivic1997's Avatar
Default Re: How much does your race EG hatch weigh?
Yes I went to ipg and bought the modified cams. It is a must sad to say. But you can still have a very competitive car none the less.
Old 03-17-2014, 05:50 AM
  #77
I'm not Rick!
rick_rabies's Avatar
^what car is this sccacivic? do you have a pic
Old 03-17-2014, 05:53 AM
  #78
Yea it's in my album I just put it on the trailer last night waxed it ;0
Old 03-17-2014, 05:56 AM
  #79
I'm not Rick!
oh ok cool. (to clarify its not an eg hatch like title says) so no1 gets out of wack
Old 03-17-2014, 05:58 AM
  #80
Oh yea forgot to say that lol but still regardless if you have an ek eg or ef you must be 2700 for stl with a 2.0!! Lol I just like telling ppl I drive a Sherman tank
Old 06-14-2014, 03:30 PM
  #81
maxogsr's Avatar
Here's mines:
Dc2 gsr
k20R
cf hood
no front sb
wing
abs delete
fully gutted except for dash and door
1 bucket seat (sparco pro 2000)
oem window
weld in roll bar (50lbs)
2250lbs with 2/3 full of gaz
my goal is 2100 witch should be possible...
I've seen some dc2 in some magazine that claim to be under 1900... That's 350 lbs less than mine... that's about the engine weight so I don't know how they make it happen!...
Old 06-15-2014, 02:52 AM
  #82
flip_nl's Avatar
A buddy of mine own an 1900lbs integra, the car has gutted dash CF doors, CF trunk/hood and lexan windows in addition to your setup. So that would be an extra 200 lbs? Can't remember if this was with a full tank or not. Anyhow I've seen the value on the scales so no story telling here. However due to aero modifactions the car should be heavier now lol.
Edit:
without driver and fuel
with driver and fuel
Old 06-15-2014, 04:29 AM
  #83
maxogsr's Avatar
That's quite light for a dc2 chassis! But the cross weight is "$%!y! lol!
Mine is still plate for the road...so I can drive it to the track witch is 15mins from my place...!
Old 06-15-2014, 06:03 AM
  #84
scottdh20's Avatar
2515 ...she's a heavy pig for being a CX with me(280-300) and about 5-6gal of fuel
I have done almost nothing for weight savings and only added weight. it has a cf hood and knock off spoon mirrors. big ole turbo kit has been added, auto power roll bar, full interior, added things like lower radio control, addisional chassis bracing, rear discs, so I fattened her up quite a bit.
when I was n/a years ago I weighed 2180 with me and 1/2 tank....that was gutted, race seats, all kinds of **** off and I was 100lbs lighter
Old 06-15-2014, 01:02 PM
  #85
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
94 civic Vx w/ turbo gsr, rear disc, type r brakes up front, sway bars front and rear, full interior,100 lbs of stereo equipment, full 10 gal tank of fuel, and me (235lbs.)= 2600 lbs. Only thing removed was sound deadening.
Old 06-16-2014, 07:10 AM
  #86
donut.'s Avatar
my 98 gsr weighs 2100. b18c1, no abs, itr roof, fal rear glass, fr and rr aero, with ps., no sound deadening, no door panels or side windows, half dash, no heater/ac, autopower roll bar
Old 06-17-2014, 05:25 PM
  #87
joel n's Avatar
95 Del Sol VTEC. Full DOM cage, EVO seat, gutted doors, rear glass, rear bulkhead, manual steering, B18C motor, half rad, oil cooler, cool suit kit, 5LB extinguisher, 10LBS battery, A/C system removed, ABS removed, gutted hood, trunk and roof. no headlamps or fogs.
2460LBS. 1/2 tank gas, 195LBS driver.
95 civic CX (Canadian model) D15B7, manual trans. No PS, ABS, A/C, sound deadening or radio/speakers. Manual everything, full interior, full glass. Stock body. 15X6.5 rota slipstream, 225/50/15 R888s.
2230LBS, 1/2 tank, 195LBS driver.
Old 01-08-2015, 06:09 AM
  #88
PURE Tuning's Avatar
Our EK Time Attack hatch weighs in at 1840 dry and 2051-2060 with driver coming off of the track with ~1.5 gallons for fuel on board. There is still quite a bit more weight to be saved by redesigning components.
More details on the car can be seen here.
PURE Tuning - Civic EK K24 Time Attack
This if from 2012 NASA Nationals.
Old 01-08-2015, 06:58 PM
  #89
FABEL's Avatar
^ have happily followed this car.
incredible devotion to making the very most of an EK chassis. certainly will be respected/admired for quite some time. please don't ever give up on redeveloping this car multiple more times into the future.
Old 01-08-2015, 10:26 PM
  #90
liam821's Avatar
My eg si was 2150 in H2 trim - b16a, gutted doors/interior, full cage, cf hood. Now that i've converted it to hill climb/TA it's a bit heavier because of the turbo parts but only by 25-50 pounds.
Old 01-09-2015, 03:55 AM
  #91
DixielandImports Please
ReDemoN's Avatar
My CX is 2050 at race weight
Almost a full tank of fuel.
K20 Swap
Old 01-11-2015, 09:59 PM
  #92
ginsu2k's Avatar
FYI My street/race EG '94 Civic Coupe was recently weighed in at exactly 2200lbs or 1000kg (low fuel)
Lots of gutting, probably better to tell you what I kept.
One stock seat, stock dash, stock carpet and kept the rear seat back to keep the trunk separate for street use, everything else non-structural was disposed of.
Of course, took out all the sound deadening, and either drilled holes or cut out chunks of sheet metal on non-structural parts (i.e. hood, rear deck lid, front bumper beam (kept for street crash protection)). The rear bumper was deleted, it weighed 13.2 lbs!
This is my weight list for the unsprung suspension bits:
Part Description Weight (lbs)
Front Suspension
Nissan J30t Dual-Piston Calipers 9
15x7 ASA Wheels 18.2
Bridgestone RE910 205/50/R15 Tires 22
10.3" Brake Rotor 23mm Thick 8
4 Lug Civic Knuckle 15
Brake Pads 2
Front Lower Control Arm 12
Upper Control Arm 4.5
Koni Front Shock 6
Eibach Front Spring 4
Front Half Shaft 12
Tie Rods 2
Total 114.7
Rear Suspension
92 Civic Si Rear Trailing Arm 38
Rear Lower Control Arm 4
Rear Brake Caliper 6
Rear Upper Control Arm 1.5
Rear Toe Control 1.5
Rear Koni Shock 6
Rear Brake Rotor 9.3" 6
Eibach Rear Spring 4
Total 107.2
Old 05-06-2015, 05:20 AM
  #93
sowellman88011's Avatar
My 92 si weighed in at 2048 w/o my big *** and 3/4 tank.
built b16 with catch can
odessey battery moved to the back
removed sunroof with kevlar roof cap installed
gutted interior with gutted dash except cluster
2 seats with slider rails 1 sparco evo3 on pci and 1 old sparco reclinable on sparco
4 point cage
I took all the sound deadening which was like 25lbs
but I do street it and drive it to and from the track so i sprayed lizard skin insulation on the floor then rubberized it. that added 7lbs back in.
custom header and exhaust stainless thru the resonator then aluminium back. the alum sect weighs about 8 lbs.
enkei rpf1s
27
04-06-2011 06:31 PM
0100
04-04-2011 05:23 AM
efboy
12
01-27-2006 03:24 PM
litterbox
11-22-2005 08:16 AM
btleier
11-09-2003 05:37 PM
Quick Reply: How much does your race EG hatch weigh?
