What are the symptoms of bad turbo seals?
Old 03-14-2004, 09:27 PM
Hoosier Daddy's Avatar
Default What are the symptoms of bad turbo seals?
I think I may have blown seals. I don't know how this could be, seeing as the turbo is almost new, but if you could list some symptoms of bad seals, i'd really appreciate it.
Old 03-14-2004, 09:40 PM
TECH43 RACING INC.'s Avatar
Default Re: What are the symptoms of bad turbo seals? (Hoosier Daddy)
oil leaking into the turbine housing and burning....(smoke coming out of the exhaust) if its turbonetics...i've seen a ton of there stuff leak, BRAND NEW.
Old 03-14-2004, 09:58 PM
Default Re: What are the symptoms of bad turbo seals? (TECH43 RACING INC.)
It's a Garrett T28. My car does smoke and reak of oil. Sometimes it smokes badly, other times it does't though. Everything on the motor is either new, or good, so i've ruled it out to bad turbo seals.
Old 03-14-2004, 10:03 PM
beepy's Avatar
You're probably right. The seal is bad. How it could have happened? Most T-28s are just a T-25 that was rebuilt and bored out to accept a larger compressor wheel. Perhaps the rebuilder didn't do as good of a job as you would hope.
Did you get it from Stone Racing? Their stuff seems to be pretty crappy.
Old 03-14-2004, 11:19 PM
Default Re: What are the symptoms of bad turbo seals? (beepy)
I'm not sure where it originally came from.
Old 03-14-2004, 11:23 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">I think I may have blown seals. I don't know how this could be, seeing as the turbo is almost new, but if you could list some symptoms of bad seals, i'd really appreciate it. </TD></TR></TABLE>
You can always check your downpipe for oil....
Old 03-14-2004, 11:45 PM
Default Re: What are the symptoms of bad turbo seals? (liam821)
That's true, I was also told to check IC pipes.
Old 03-15-2004, 06:37 AM
eghatchproject's Avatar
The return line can also play a role in this right? I mean if it is kinked and hindering oil flow it is feasible that it would get past the seals. I have oil getting past my brand new T3 Garrett turbo seals but I'm using 5w30 synthetic and I'm switching to 10w30 synthethic very soon.
Old 03-16-2004, 08:04 PM
Default Re: What are the symptoms of bad turbo seals? (eghatchproject)
I've heard about that. My return line isn't kinked in any way though.
Old 03-17-2004, 05:00 PM
New User
integrx's Avatar
i have oil in my IC pipe , probably turbo seals
Old 03-22-2004, 09:53 PM
Default Re: What are the symptoms of bad turbo seals? (integrx)
Can anything else cause this? PCV? Oil pan gasket? Anything? If I look under my car there is grime all over the place, as if oil is squirting from somewhere and sand from the road is sticking to it. It's all over the oil pan, downpipe, IC pip, driver's side suspension etc. Mostly, if not only on the driver's side. Could this be my oil pan gasket?
Old 03-23-2004, 11:50 AM
ANyone?
Old 03-23-2004, 09:39 PM
Phaze2 Mike's Avatar
only something internal to the exhuast system could cause exhuast smoking. Three major items are piston rings, valve guides/seals, and turbo seals, best possible situation turbo seals.
Old 03-23-2004, 10:33 PM
Default Re: (yellowfever)
I was wondering what the grime underneath my car could be. Hopefully something minor, like the oil pan gasket.
oh_dam
06-20-2010 11:21 AM
BlackDAy
09-16-2005 07:57 AM
pornstarSR
09-24-2003 10:47 PM
B_1_8_hatch
08-31-2003 07:55 AM
E-Rok
12-19-2002 08:14 PM
Quick Reply: What are the symptoms of bad turbo seals?
