Timing belt cover for a b20 vtec.
Old 01-27-2014, 06:22 PM
MegustaVtec's Avatar
Icon2 Timing belt cover for a b20 vtec.
Can anyone share from what motor timing belt covers can be use on a b20vtec with a b16 head. I have been looking around and I hear different comments. Can I use all gsr covers. Or b20 bottom and both b16 upper covers.
Old 01-27-2014, 06:25 PM
B_Swapped93's Avatar
Default Re: Timing belt cover for a b20 vtec.
Any year b20 block cover and any year vtec b-series upper
Old 01-28-2014, 05:35 AM
kyden's Avatar
any obd2 lower cover (if using pump with ckf sensor provisions). GSR/ITR upper covers. You will have to shave some off the back of the inner cover if you want that to fit.
Old 01-31-2014, 02:23 PM
the bottom block is jdm. what if I use a the upper covers from a 2000 si. do I have to shave the back to make it fit.
Old 01-31-2014, 02:52 PM
I am Jack's...
Tyler Dirden's Avatar
Here's the facts:
There is very little effort to make the complete timing set work and fit excellent. The pictures show a tiny little tab that gets removed from the block rear cover and a tiny slot made for a rib on the motor as shown. Afterwards it will fit excellent and allign almost perfect with the upper cover except for a very small, nearly unnoticable gap on the rear where they are meeting with the water pump. Not a gap really, just spread apart slightly, but fits with all the hardware fine.
Old 01-31-2014, 03:06 PM
thanks for the pictures. those covers are from a gsr/type r.
akira712
12-07-2006 06:45 PM
Tarmac Junkie
10-02-2006 09:07 AM
96MidoriHatch
09-04-2004 12:14 AM
Hoosier Daddy
12-29-2003 02:45 PM
Quick Reply: Timing belt cover for a b20 vtec.
