Radio Antenna won't go down anymore
I got a 00 GS and my radio Antenna won't go down anymore when I turn off the radio. I can hear that its trying to go down but it doesn't.
Re: Radio Antenna won't go down anymore
Mine did that. The guys at the car wash "fixed" it by hand though. Now its permanently down... (Just push hard and it will go down, further stripping the already failing gears / motor.)
^ don't do that if you ever want it to work again.
You can get a new mast off eBay for around $25. The motor gears are not stripped. The nylon string gear attached to the mast breaks. The mast is easily replaced.
http://www.team-integra.net/sections...?ArticleID=914
Correct. I should have stated that. Mine will never work again (correctly) after that.
If I didn't have metallic based window tint, I'd already have put a "hidden antenna" on it. For LA area though, it works well enough when its down, and some day I'll do the S2000 antenna swap.
just replacing the antenna is --almost-- a tool-less job
you know your actuator is good since you hear it
you can get a new mast on ebay for about $17(us) incl shipping
thats what mine cost
the only tool I recommend is an antenna wrench, they are cheap and keep you from scaring up the nut on top (or the paint)
1)
remove the antenna nut
(it can be difficult to slide over the end of the antenna, but it will )
2)
turn on the radio so the motor is in the UP position
3)
yank the mast out
yes, just pull it out
4)
extend the new mast and insert the nylon cable into the empty hole
NOTE: cable must have the ridges facing towards the drive gear, this will be the front or rear of car, I think my new mast had a sheet that told me
5)
turn off the radio and feed the new mast into the base as the motor pulls in the cable
(you may want a friend to work the radio power unless you have more than the usual 2 arms)
6)
put on antenna nut (remember it may be difficult to get over the top of the antenna but it will go)
7)
practice your pirate moves with old antenna mast while jammin to the radio
1)
2)
3)
yank the mast out
4)
5)
6)
7)
eight equals equals equals D
See, I couldn't use that method, bc the previous owner of my car, jammed the antenna in the down position, and somehow that plastic cable with the ridges broke into several pieces inside the motor. When I tried to get all the pieces out, I broke the motor.
HondaHeddies method sounds pretty easy to me.
Honda isn't the only company using power antennas. And they all break over time - that nylon string gear attached to the mast. What sucks about it is that most people will take the car to the dealer - ANY dealer - and get quoted $200 to replace what amounts to a $20 part and 30 minutes of labor.
replace it with some shorty antenna like the s2k or leave it down. when i had my teg i replaced the mast twice. so finally just said **** it and pushed it down, and pulled out the actuator.
Bringing this thread back to life
The antenna on my Integra is able to come out when I turn on my radio. But when I shut it off it doesn't retract and I hear multiple thudding noises from the trunk. In order to put my car cover back on I just push it back in. Reading from the comments this is a bad idea, however, whenever I turn on my radio the antenna is able to come out to it's full height without any problems. What do I need to replace to get the antenna to retract itself after shutting off the radio? It sounds like I need a new mast? But I want to make sure before I buy anything.
Also, I'm interested in doing the S2k antenna conversion as this sounds like a solution that will avoid replacing the antenna over the years. Has anyone done that? If so, is the antenna assembly (39150-S2A-A01) enough to do the job or do I need to get the feeder as well (39159-S2A-013)?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Old Fart
I have not had any problems with my power ant. on my 94 RS, the trick is to keep it clean and lubed, [dry lube].
As mentioned the mast is easy to replace. 94
