How to check for bent valves.
Old 11-19-2008, 04:38 PM
JBirch_97Prelude's Avatar
Icon2 How to check for bent valves.
I have decided to take my car out of the shop where it's been for weeks without progress. I was originally told that I had bent valves so I am wondering how to check which valves are bent so I can have them replaced. The new head was put on and I was told that compression was to low and that they needed to do a leak down test. I thought the only way to check compression was with a leak down test. Anyway if there is low compression what good would a leak down test do.
Any help would be greatly appreciated!
Old 11-19-2008, 04:55 PM
ethereal2pt2's Avatar
well how low is low? if you have bent valves, that cylinder shouldnt' be able to hold very much pressure if at all. that and the engine would run like **** and you would KNOW. my guess is that you don't but w/o more info can't say for sure.
Old 11-19-2008, 05:34 PM
Low hundreds! How could compression be checked without a leak down test!
Old 11-19-2008, 06:49 PM
jay24k's Avatar
Why not just do your own compression test? You can tell which ones are having issue that way.
Old 11-19-2008, 08:55 PM
personally i've experienced bent valves and let me tell you even an, excuse me, retard would know that he had bent valves. your engine would run very very rough especially at idle. if you're pondering this, most likely you don't have bent valves. but a leak down test would help to indicate where your engine is at in terms of health. just got to autozone and borrow their kit. do it yourself.
Old 11-19-2008, 09:05 PM
95greenlude's Avatar
^your car wont necessarily run bad if you have bent valves. If their slightly bent, there's a good chance you wont even notice.
A compression test will tell you if your motor is in good health and holds compression in the combustion chamber.
A leak down test will tell you WHAT is not healthy in your engine, and where compression isn't being held
Old 11-20-2008, 01:05 AM
dagle's Avatar
well OP did specify that he got compression test results of low 100's.. which indicates that something is definately wrong.. if it isn't the head, it sounds to me like your block is the problem. however, as mentioned we cannot tell you over the interweb with the information given. get back to us with the info we're looking for and we can help you out.
Old 11-20-2008, 03:03 AM
That's the thing, I don't know what info i'm getting back is true or not so I am thinking about taking it out of the shop and working on it myself!
Old 11-20-2008, 04:36 AM
Acidcrakker's Avatar
I remember your post from a while back. Its a shame that no one has even done anything to fix it yet, that was a while ago.
Im not that far away from where you are, and I do make local calls when someone needs a hand with stuff. I can come over there, take your head off and take it to a machine shop that can competently install new valves for you.
Old 11-20-2008, 06:14 AM
The head is off! I am picking it up today but I don't think they are all bent! Unless you suggest I replace them all. When do you think you can come by, I will pay you for your time!
Old 11-20-2008, 08:09 AM
Well if the head is off. Than checking each cylinders valve is going to be a bit of a hassel, I can pick the head up have it inspected for damages other than bent valves, have it fixed, then reinstall the freshly revalved head for you. And you should be good to go.
I can come out Saturday some time.
Send me a PM so we can iron out the details.
Old 03-09-2021, 11:31 AM
logan -'s Avatar
Default Re: How to check for bent valves.
I had my balance shaft pulley fly out of the timing cover on me the other day there, I was in there recently to put I a retainer clip and I had it back up running everything torques to spec but I guess this pulley needed locktite. I’m trying to figure out if I have bent valves or not, is there a way to figure this out without going out and buying a new belt and a new pulley ? Help would be much appreciated.
Old 03-09-2021, 12:03 PM
Premium Member
Aradin's Avatar
If the engine timing belt and pulley stayed in place, the engine should be fine. The balance shafts/belt/timing have no effect on the valvetrain. These engines are commonly run without a balance shaft belt to improve performance and lower oil temperatures.
Old 03-09-2021, 02:48 PM
logan -'s Avatar
thank for the info helps a lot, forgot to add the timing belt actually snapped in half and to take the crank pulley off to take the timing cover off to get at the timing components I would near to turn the crank at least a little bit to hold it steady to break the crank bolt but the cams don’t move with it. Any suggestions?
Old 03-09-2021, 03:01 PM
Premium Member
Aradin's Avatar
If that's the case I would just recommend removing the cams altogether so all the valves will be closed. You can then apply compressed air into each cylinder and check for leaks. If you have any big leaks or hear hissing into the intake/exhaust then it's likely you have bent valves.
The Dirty EJ1
06-30-2008 12:37 AM
leeminho86
05-18-2006 08:14 AM
RGoose18
05-21-2004 10:13 AM
LostGsr
06-15-2001 12:29 PM
Quick Reply: How to check for bent valves.
