Header benefits on a d16y8??
Do any of you guys know if it will make much of a difference in my 97 civic coupe ex coupled with intake and exhaust piping at 2.25 and a high performance muffler to place a header on it?
I've been considering the DC Sport 4-2-1 two piece, and does anybody know much about that header(clearence, quality,etc...)
Will it make much of a difference in my power????
Modified by G-CIV at 5:15 PM 6/17/2005
Re: Header benefits on a d16y8?? (G-CIV)
If you search at all you will find something usefull. Take a note: typically, using an aftermarket header will be one of the most noticable power gains. This is true for practically any make or model. Non FI of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-CIV »</TD></TR><TR><TD CLASS="quote">sweet, thnx for the info,...does an aftermarket intake manifold make much of a difference? like the skunk 2 one?</TD></TR></TABLE>
Not as notable. The intake manifold goes up in effectiveness the more HP you create
Re: Header benefits on a d16y8?? (Revolver)
so should i buy some haeders? i mean is the difference that i will notice be worth the $250 that i would spend on some header?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-CIV »</TD></TR><TR><TD CLASS="quote">so should i buy some haeders? i mean is the difference that i will notice be worth the $250 that i would spend on some header?!</TD></TR></TABLE>
You need to spend quite a bit more time researching this site, because you've asked alot of general questions so far.
You will spend alot of money on bolt ons for that engine, and maybe gain 10hp. It's not a good $/hp benefit; and you probably won't notice any difference on the street.
You should make a plan of ultimately where you want to go. If you really want to make some power, you'll either need to build or go FI, that's where these extra parts start giving some gains by optimizing your system.
I'd wait a while, figure out what you really want to do with the car, then start researching what parts will work best for your needs and application. But if you really just want to mod your car to mod or whatever, then go ahead, but you may realise later that you wasted the money and have to buy the parts all over again.
Re: Header benefits on a d16y8?? (AutoXer)
A 4-2-1 header is the way to go for daily driving for it gives the best mid-rpm gains. A 4-1 header gives better high-rpm gains, but not much mid-rpm gains if any. You will probably get at most 5 hp from a 4-2-1 header on a D16Y8. Here is a dyno graph from a Comptech 4-2-1 header on a D16Y8:
http://www.comptechusa.com/ima...t.pdf
civickidd99
11
10-11-2003 12:00 AM
