Integra 1.8 timing marks
Re: Integra 1.8 timing marks (Chickomenon)
on which part are you talking about, the crank pulley?
On the crank pulley there is a single white mark indicating TDC, and 3 red marks to the left of the TDC mark, indicating the stock ignition timing setting of 16 deg. +/- 2 deg. BTDC. The middle mark is 16, the mark towards the white mark is 14, and the mark farthest from the white mark is 18. Many people set their timing to 18 BTDC to gain a little extra hp. Just be sure you ALWAYS use premium gasoline if you do this, though.
Re: Integra 1.8 timing marks (PatrickGSR94)
what do u mean by premium? Like Does that mean just run high octane..like i always put 93 in would that fine fine? sorry for the stupid question..My timing seems to be off so i wanna set it to where i should ahve it.
