Mig welding Question
Old 12-02-2007, 11:13 AM
91ed9's Avatar
Default Mig welding Question
Welll so its Flux/Mig welding i dont have gas yet, so anyways
Lets say i tac something in, now when i go to weld a bead around, as soon as i start to weld it like flashes and then the wire like gets stuck inside the tip and then doesnt come out . I have to take off the tip and then cut the wire, then put the tip back on
what can this be i know the ground wire is good metal to metal contact and the welding area is cleaned good also do you think it could be the wire?
the welder is from harbor freight {its a Chicago Welder, 170 amp 230V }
thanks
-John
Old 12-02-2007, 12:17 PM
Bailhatch's Avatar
Default Re: Mig welding Question (91ed9)
add more wire speed maybe
Old 12-02-2007, 01:41 PM
m R g S r's Avatar
is the tip far enough away from the workpiece? sounds like you have it right on the work. . . .
Old 12-02-2007, 02:41 PM
Syner-G-Racing LLC's Avatar
Default Re: Mig welding Question (m R g S r)
it sounds like your leading to much wire out of the tip. you should have 1/8- 1/4" of wire no more unless your just $h!t out of luck on getting the nozzle close enough to welding properly.
other than that, how thick is the metal your welding and whats your current setting?
Old 12-03-2007, 10:21 AM
91ed9's Avatar
Default Re: Mig welding Question (Syner-G-Racing LLC)
well i usually have the wire about 1/4" away from the tip. The material was i think 1/8 thick about, wire speed is around 4 and the heat setting is about 5 out of (1-6)
im not to sure about the wire thickness i think its .30"
i mean once it getts going to welder works very well but alot of the time it just doesnt want to start welding it will either flash and then get stuck or it will just like sputter ( or like jump)<- im talking about the arc
-john
Old 12-03-2007, 07:51 PM
dont know man. if the tip isnt wallowed out...
I would say turn it up to 6 and turn the speed down to 3.5-4 and see if it works any better if not...?
how is it setup? when you run innershield the work cable should be positive and the wire block should be negative. That would posibly be your problem.
Old 12-04-2007, 08:07 AM
91ed9's Avatar
maybe i have the polarity wrong on the wires, bc the welder is interchangeable gas or non gas
ill check when i get home from work tomorrow
any more input from people are welcome please
Old 12-04-2007, 11:45 AM
97EKRADKEN's Avatar
You should turn the heat up on the welder?
Old 12-06-2007, 11:12 AM
91ed9's Avatar
Default Re: Mig welding Question (97EKRADKEN)
^ is that a question or a statement?
do you guys think that the flux wire could be f-ed? maybe it will weld better with gas argon/co2
-john
Old 12-06-2007, 01:28 PM
XLR8 GS-R's Avatar
170 amps and 220volt its not a crappy welder. You said your max heat setting is 6 and your running 5 turn the heat down to 3 for 1/8" but keep the speed at 4 (if the range is 1-10 for wire speed?) That welder can probobly do 1/4" no problem. Usually when you get wire burn back your tip is touching the work piece and the tension setting (or drive rolls size) on your wire feeder is way to tight. Let some wire out of the gun and hold it close to the tip with a pair of pliers. Loosen the wire feed **** untill the wire slips (dosent come out of gun) instead of pushing your pliers away. Stick with flux core till you know how to weld. Gas is just another thing to worry about
Old 12-06-2007, 01:30 PM
XLR8 GS-R's Avatar
Default Re: Mig welding Question (XLR8 GS-R)
oh make sure your drive roll wire diameter- your wire and your tip are for the same size. Liners and tips can run 1 size bigger no probs
Old 12-08-2007, 02:03 AM
Gas isnt a worry...set it to 32 cfm, (my bad 32 scfh) and go to town...its way easier to weld with gas than with out it. I recommend learning to stick and innershield then move up to gas...but it realy doesnt matter your learn either way.
Modified by Syner-G-Racing LLC at 11:33 AM 12/8/2007
Old 12-08-2007, 04:17 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing LLC &raquo;</TD></TR><TR><TD CLASS="quote">Gas isnt a worry...set it to 32 cfm.</TD></TR></TABLE>
are you serious with that? 32cfm ?? ive never used my gas at that rate.
Old 12-08-2007, 05:21 AM
91ed9's Avatar
i dont have gas yet, i need to buy a tank and then find a place in the area to filler up.
but maybe the wire feed is to tight. and the tip and wire are the same size im pritty sure bc i know i gott 2 different size tips and i made sure they were the right size... im off tomorrow so i will check everything out with the wlder ( you dont htink the ground could be a problem i mean i wire wheeled everythign i was welding and where i put the ground clamp, im not sure .... is there another way to get the welding area cleaned so i coulkd get better penitration
thanks for the help guys,
anymore imput will be appreciated
-John
Old 12-08-2007, 11:19 AM
Default Re: Mig welding Question (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">
are you serious with that? 32cfm ?? ive never used my gas at that rate. </TD></TR></TABLE>
absolutely! I do all my welding outside, or with an open bay door. 32 scfh
as far as finding gas look up airgas, air liquide you can buy the bottle from them or rent it for like 15 cents a day. its about $230-250 for blueshield or argon w/ a 60 scf bottle.
Modified by Syner-G-Racing LLC at 11:32 AM 12/8/2007
Modified by Syner-G-Racing LLC at 11:44 AM 12/9/2007
Old 12-08-2007, 11:28 AM
91ed9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing LLC &raquo;</TD></TR><TR><TD CLASS="quote"> its about $230-250 for blueshield or argon w/ a 60 scfm bottle.</TD></TR></TABLE>
for a 60scfm bottle filled?
bc i could get an empty one for like 100 but id have to find a place to fill it
Old 12-08-2007, 12:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">
bc i could get an empty one for like 100 but id have to find a place to fill it</TD></TR></TABLE>
yeah filled, you could buy your own bottle but you have to pay for the bottle to get inspected and stickered which after everything it will be pretty close to what they charge...if your lazy and dont feel like jumping through hoops just buy from the supplier. just look up airgas, gaspro, or air liquide....if you still cant find a supplier go to the nearest restaurant or hospital and ask someone where they get their co2.
it looks like all the suppliers for your area are in NJ
Old 12-08-2007, 02:37 PM
91ed9's Avatar
yeha which sucks i dont want to drive all the way to NJ just to get some argon
Old 12-09-2007, 10:57 PM
so you never said if it was wired up for innershield or not...
Old 12-10-2007, 01:46 PM
91ed9's Avatar
oo yeah im sorry , tis wired up correctly for the innershield which i am using fluxed core wire
Old 12-15-2007, 11:59 AM
91ed9's Avatar
FIXED! well someone said that the wire feed was to be adjusted well i tried that and nothing, but then i was like what about the bolt holding on the wire ROLL well thats what it was the wire roll was to tight loosed it up and its coming out ALOT faster and it doesnt sound like the motor is struggling!!!!!
and I GOT GAS haha i found a local welding shop not far that i never knew wat there and i bought a 60 scfm tank and i think the gas is like 25 bucks to refill
cash was 170 filled! but i need a fitting to put the hose on from the regulator to the tank and no one HAS it. idont know why i went to homedepot , a local hardware store , the only place i didnt go was a plumbing store...... they were closed
Spicoli v 3.0
Audio / Security / Video
23
05-03-2007 05:25 PM
twilightprotege
Welding / Fabrication
05-22-2006 04:52 PM
supercreed2002
03-15-2006 09:45 AM
adictionbass
08-13-2004 07:15 AM
redteg1
03-20-2002 08:47 PM
Quick Reply: Mig welding Question
