Mig welder argon gas setting?? Anyone?
Old 10-02-2008, 11:49 AM
JDMCRX's Avatar
Default Mig welder argon gas setting?? Anyone?
I borrowed my buddies licoin sp-135 and i need to know what to set the CFM to. just doing 20gu steel welding.
Old 10-02-2008, 12:12 PM
MilwaukeeMotorwerks's Avatar
run 15-20
Old 10-03-2008, 08:58 PM
postman's Avatar
Default Re: (MilwaukeeMotorwerks)
you should be running mix gas
Old 10-04-2008, 09:44 AM
JDMCRX's Avatar
Default Re: (postman)
Yeah i know im just doing body work. My tig uses argon so im just gonna use that.
Im doing a tiny bit of body work should be ok with the argon tho ?
Old 10-04-2008, 09:57 AM
ExVtec's Avatar
Default Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i know im just doing body work. My tig uses argon so im just gonna use that.
Im doing a tiny bit of body work should be ok with the argon tho ?</TD></TR></TABLE>
It will work. Seems like the "ideal" mix is 75/25 argon/cO2
15-20 seems to work great for most mild steel apps.
Old 10-04-2008, 01:51 PM
9295EJ-t's Avatar
argon wont work well at all.. you need a mixed gas... 75/25..
as far as cfm settings, anywhere from 15-30cfm, depending on the wind factor, will work...
Old 10-04-2008, 04:20 PM
fastcody1's Avatar
Default Re: (9295EJ-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9295EJ-t &raquo;</TD></TR><TR><TD CLASS="quote">argon wont work well at all.. you need a mixed gas... 75/25..
as far as cfm settings, anywhere from 15-30cfm, depending on the wind factor, will work...</TD></TR></TABLE>
just like the mix wont work with the tig
Old 10-04-2008, 09:24 PM
ExVtec's Avatar
I have heard of people using mig gas mixtures on tig before b/c thats all they had. It wasn't perfect but it was better than nothing...is this not the case?
Old 10-05-2008, 07:38 AM
JDMCRX's Avatar
Default Re: (ExVtec)
Or would i be better using the flux core wire??
Old 10-06-2008, 05:42 AM
9295EJ-t's Avatar
just dont try welding with straight argon if gravity is gonna be pullin on the molten bead while welding..
like an overhead, or vertical bead.. flat should be okay... it just might lack penetration.
Old 10-06-2008, 07:07 AM
JDMCRX's Avatar
Yeah the argon was not pentrating properly. I just used the flux core wire splatters a bit but penitrates well. Ill just grind it down a bit on both sides. and prime and paint better.
whiteformula98
Paint and Body
08-07-2008 06:45 AM
Hondasi88
Mid-Atlantic (Sales)
01-05-2008 07:39 AM
msinsky14
Welding / Fabrication
18
08-05-2007 03:18 PM
phatrick2332
10
02-17-2005 05:59 PM
The Alchemist...
01-23-2005 12:24 AM
Quick Reply: Mig welder argon gas setting?? Anyone?
