Gas Cylinder?
Old 04-28-2005, 07:02 AM
Boosted96EK's Avatar
Default Gas Cylinder?
Anyone ever use a nitrous bottle as a cylinder to hold your argon to weld?
Old 04-28-2005, 12:44 PM
beepy's Avatar
Default Re: Gas Cylinder? (Boosted96EK)
Do they use the same DOT certification?
Old 04-28-2005, 04:28 PM
new2novas's Avatar
Default Re: Gas Cylinder? (beepy)
I don't think so...becuase i think most nitrous systems run around 1000psi while your argon is stored at 2200 or so psi. Although i am not sure what the actual nitrous bottle is capable of holding, it may be enough, but i doubt a station would even fill it....you could always buy your own bottle and paint it
Old 04-28-2005, 05:37 PM
OG Fabricator
Engloid's Avatar
Default Re: Gas Cylinder? (new2novas)
If you find a company that will do that, they're ******* idiots. It is illegal to do that. Not only that, but your flowmeter won't hook to a nitrous bottle.
If it were that easy to find a cheaper alternative, somebody would have already come up with it.
There's laws and regulations about putting gasses into bottles, and such. Anybody that will put aargon in a nitrous bottle is likely risking huge fines and jailtime... and they don't want to do that so you can save $50.
If you think finding an exhaust shop that will take out your cat converter, just try and find a place to put argon in a nitrous bottle.
Old 04-29-2005, 08:33 AM
Default Re: Gas Cylinder? (Engloid)
a simple no would have been just fine
it was just one of those hey i wonder if kinda things... At any rate I was calling around town yesturday and found a company that would sell me a new 40CF cylinder with argon/c02 mix for about $100.. Refils are about $22.
Old 04-29-2005, 09:32 AM
EPIC TUNING
E-Rok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">
i actually had a midas replace my cat with a test pipe, i was shocked that they said ok.
Old 04-29-2005, 10:44 AM
parasonic's Avatar
Get the 80.
Old 04-29-2005, 12:10 PM
new2novas's Avatar
Default Re: Gas Cylinder? (parasonic)
yeah get the 80...little more expense now, but when your in the middle of a project and forgot to check you pressure and you run out, you'll wish ya did. plus its cheaper to get filled, well cheaper as in you get a bulk type discount
Old 04-29-2005, 08:36 PM
parasonic's Avatar
80 still isn't that big. You just probably don't want to have to find time every time that you have a MINOR project to get a refill. I run out of 80's quickly. Sad, yes, I know. It might be time to upgrade.
Old 05-01-2005, 04:47 PM
One more question... can acetelyne or oxygen cylinders be used for argon?
Old 05-01-2005, 06:21 PM
ManBearPig4silly's Avatar
Just buy/lease the proper setup from your local welding supply place. Your safety is not worth saving $50....nevermind the fact that you will be buying a tank that no place will fill. So where is the savings then? You have a tank you cant use.
Old 05-01-2005, 07:46 PM
parasonic's Avatar
Default Re: (Boosted96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted96EK &raquo;</TD></TR><TR><TD CLASS="quote">One more question... can acetelyne or oxygen cylinders be used for argon?</TD></TR></TABLE>No, but you can probably find a place that will exchange them.
nitrousfinder
02-12-2013 01:46 PM
Type-R eg6
22
06-08-2010 06:38 PM
xQwertyx
04-24-2006 04:01 PM
torqueless
09-25-2005 12:54 AM
Almost
02-15-2005 05:45 AM
Quick Reply: Gas Cylinder?
