Transmission & Drivetrain Gearboxes, Differentials, Clutches
Short Clutch Release and Vibrations Constantly! HELP!
Old 08-08-2013, 10:03 AM
Ls1Powerz's Avatar
Default Short Clutch Release and Vibrations Constantly! HELP!
Okay so I've searched far and wide and found nothing similar with any results.
I've got a 93 DX Coupe with an LSV Swap and S80 Transmission. Recently I noticed my clutch would engage really close to the floor from time to time but always thought I was imagining it. Well I replaced my rear motor mount and sure enough it does this all the time now. It also has a weird vibration when you're not fully engaging the clutch as well as a slight squeek at idle.
Is this a hydraulic problem or a mechanical issue that I can solve by swapping a new trans in?
Old 08-08-2013, 06:46 PM
m90polk1's Avatar
Default Re: Short Clutch Release and Vibrations Constantly! HELP!
The noise could be from either input bearing or clutch release bearing, or the squeek could be from the rubber on the new engine mount depending where the sound is coming from .....as far as it releasing very early, how new is the clutch? Is the clutch release bearing installed correctly? Also is the clutch shift fork bent? All could be possibilities to why it is releasing "early".
Old 08-09-2013, 10:01 AM
Ls1Powerz's Avatar
clutch has less than 6k on it. its a six puck if that helps anything. it never really gave me any problems until recently and a shop did the install so I assume it was done right.
MiNeSEK
19
05-11-2013 12:05 AM
sageuvagony
07-16-2007 12:30 AM
renes
11-21-2005 11:25 AM
m3dia_lab
10
11-11-2004 06:25 PM
JdmFront619
10-28-2003 12:25 PM
Quick Reply: Short Clutch Release and Vibrations Constantly! HELP!
