Transmission & Drivetrain Gearboxes, Differentials, Clutches
Crv transfer case to corvette c4 ids help!!!!!
Old 05-20-2013, 07:11 AM
GOTBOOST858's Avatar
Default Crv transfer case to corvette c4 ids help!!!!!
Sup everyone. Need some help figuringnout what tire size to run for the front and back for a 4wd civic hatch project. Here is the design. Got a 2000 Crv manual Transmission and transfer case and the best closest rear end that I could find is the Corvette C4 automatic rear which is a 2.59 rear drive ratio. If the transfer case is 2.542:1 rotstion will the corvette c4's 2.59 gear ratio work sith the crv transmission with 215/45/17 front and rear? Tire total diameter is 24.6".
Old 05-23-2013, 07:40 PM
underg4's Avatar
Default Re: Crv transfer case to corvette c4 ids help!!!!!
Man have kind of the same problem but using the s2k rear diff and k 24 with element awd 5spd. If I find it I will help you out are trying to lock the rear end to work all the time?
Old 05-28-2013, 04:11 PM
Im using the Corvette C4 Dana 36 Rear Diff and the Corvette brake system on a 92 Eg
Old 05-28-2013, 04:12 PM
IF the transfer case is a 2.542 and the rear diff is a 2.59 thats only a .048 gear ratio difference. Wonder what that transforms to at the wheels?
Old 05-28-2013, 05:52 PM
underg4's Avatar
4.8% rotational difference.
Old 05-28-2013, 05:53 PM
underg4's Avatar
If they are the same size tire and rim.
Old 05-28-2013, 06:03 PM
underg4's Avatar
Wait the transfer on the transfer case isn't 1:1 so you have to account for that, it's .904:1 I think.
Old 05-28-2013, 06:05 PM
underg4's Avatar
After the transfer ratio the rear would only turn at 2.34:1
Old 05-28-2013, 06:24 PM
Seagull Management
94EG8's Avatar
Way too much.
Old 01-05-2014, 07:06 AM
Anyone know if you can cut and weld cast aluminum?
Balor_Gr
AWD Conversion Forum
20
07-08-2021 06:24 AM
grey_box008
Honda CR-V & Element
49
05-16-2013 09:27 AM
si90rex
09-12-2011 09:20 AM
Hiroshima_VTi-S
Honda S2000
10-10-2007 11:26 AM
Quick Reply: Crv transfer case to corvette c4 ids help!!!!!
