tranny leaking a little, oh what to do?!
It looks like I am leaking a little transmission fluid from the half shaft hole (the hole where the half shaft connects to the tranny on the driver's side). Is there a seal there? And more importantly, can it be replaced without pulling the tranny?
How do you check the tranny fluid level? Do you just unbolt the fill hole and start pumping fluid in until it starts to overflow?
Thanks
Thanks
Re: tranny leaking a little, oh what to do?! (hatchy)
So is there a way to check tranny fluid level without unbolting the fill bolt and pumping oil into it until it overflows?
take the bolt out, the stick your pink into it, the luid should be sitting right at the top of there the bolt hole is
jdmstyleEJ6
12
04-02-2010 08:07 PM
vtec25
03-16-2006 06:54 PM
