timing belt came loose?
ok well i have a vibration and asked my friend aboutit he says it could be the timing belt? what are signs of a timing belt going bad?
-Kyle
-Kyle
Mad Scientist
Re: timing belt came loose? (BseriesCrx)
the car is vibrating?
a timing belt wont cause the engine to vibrate, unless of course it skipped a tooth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BseriesCrx »</TD></TR><TR><TD CLASS="quote">when i take the valve cover off do i have to replace the gasket? should i anyway even if i dont have to?
-Kyle</TD></TR></TABLE>
yeah, replace it dont be cheap
Re: timing belt came loose? (mmuller)
ok i will go into gr8 detail now. it all started with a little noise from the crank pully at idle. not big i didnt think. then after about acouple days i felt alittle vibration but thou8ght it was just thye road. then after days it got worse and now its big so the vibration just keeps getting worse. tahts about it
-Kyle
-Kyle
Re: timing belt came loose? (draw)
the vibration just stopped. is that good or bad. it comes back everyonce and a while but not near as bad. did i break sumthin or did it just fix itself?
-Kyle
-Kyle
doostin
02-01-2009 04:45 PM
