which sohc head: P08-3???
Old 04-22-2003, 10:27 AM
@irborne's Avatar
Default which sohc head: P08-3???
https://honda-tech.com/zerothread?id=483242
Old 04-22-2003, 10:34 AM
Katman's Avatar
Default Re: which sohc head: P08-3??? (@irborne)
P08 is a VTi/(1.5L)sohc vtec part number....should be the same exact head found on US 92-95 Si/EX D16Z6 engines.
Old 04-22-2003, 11:00 AM
@irborne's Avatar
Default Re: which sohc head: P08-3??? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">P08 is a VTi/(1.5L)sohc vtec part number....should be the same exact head found on US 92-95 Si/EX D16Z6 engines.</TD></TR></TABLE>
how do you think this head will flow put against the y8 head? reletively comparing the heads on a y7 block
Old 04-22-2003, 11:32 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @irborne &raquo;</TD></TR><TR><TD CLASS="quote">
how do you think this head will flow put against the y8 head? reletively comparing the heads on a y7 block</TD></TR></TABLE>
I believe this head of yours (P08/Z6), flows a little better than the Y8 head in stock form.
Old 04-22-2003, 12:25 PM
@irborne's Avatar
would a distributor off a y7 or y8 work with this P08/Z6?
Old 04-22-2003, 12:31 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @irborne &raquo;</TD></TR><TR><TD CLASS="quote">would a distributor off a y7 or y8 work with this P08/Z6?</TD></TR></TABLE>
yes, but I believe only 1 mounting leg will match up to the Z6 head....it will work nonetheless.
toolbox21
07-22-2008 06:24 PM
96electronH
10-05-2007 06:35 AM
turboeg77
06-21-2006 06:34 PM
98jdm_coupe
04-15-2004 09:28 PM
EK_vzla
01-31-2004 10:52 PM
Quick Reply: which sohc head: P08-3???
