JDM B16A Cam & Crank Seal Help
I bought a 00' Si with a jdm b16a. I was in the process of replacing the front seals when the ones I bought (for a b16a2) did not fit. On the cam seal the overall outside diameter was to big. I have done about a million timing belts on about every different honda motor and have never ran into this problem.
Can someone please give me the part number for the correct ones or tell me where I can go to get them?
Re: JDM B16A Cam & Crank Seal Help
Both Camshaft and Crankshaft seals have bigger outside diameter than the ones for B16A2. I will post a picture and dimensions of what I have tomorrow.
Resident Gearhead
Hmmm...Are you buying OEM seals or aftermarket?
Both the B16A3 and the B16A2 have the same part #s for both seals.
I hate to say it like this but something isn't right on your end. Either you didn't order the right seals or you weren't sent the right seals.
what outside diameter of your seals?
mitch6
03-30-2012 01:51 PM
