high idle and distributor retard all the way
Old 11-25-2002, 04:44 PM
ls_vtec_b18a1's Avatar
Default high idle and distributor retard all the way
my built ls vtec idles at 1800 and the dis is all the way retard, the motor has pr3 pistons and a b16 head, what going on here is this a vacuum problem or what?
Old 11-25-2002, 05:05 PM
Vu
Vu's Avatar
Default Re: high idle and distributor retard all the way (ls_vtec_b18a1)
Why did you retard your timing(distributor) all the way? That will just make your car run like **** or not run at all. Put it back to at least stock timing, and try adjusting the idle screw, by the throttle body, instead. Do you have any aftermarket camshafts?
[Modified by Vu, 8:06 PM 11/25/2002]
Old 11-25-2002, 05:45 PM
Default Re: high idle and distributor retard all the way (Vu)
i tried that and the idel screw dont do ****, i got a jg bored throttle body. i got stock cams as of right now. i know when i start it its hard startn i guess thats cause the timings retard all the way but it runss good when it starts just idels high.
Old 11-25-2002, 06:19 PM
ill phil's Avatar
Have you checked your TPS voltage?
Old 11-25-2002, 06:31 PM
Default Re: high idle and distributor retard all the way (ill phil)
no how would i do that thanks
cardinalboy07
04-13-2012 06:44 AM
SRZsmack
12
05-25-2009 09:27 PM
civic_PD
09-28-2008 07:08 PM
SwappedLSHatch
04-06-2006 04:33 PM
cirionrc
04-27-2002 10:47 AM
Quick Reply: high idle and distributor retard all the way
