gsr compression #'s...too low???
Old 01-10-2002, 02:23 PM
GSR44's Avatar
Default gsr compression #'s...too low???
i just did a compression test on my 98 gsr (H/E, 50K miles) and got 165, 170, 170, 175. i've heard that gsr's should average about 200 across the board...are my compression numbers a bit low? what could be the problem? any help/advice would be appreciated...TIA.
Old 01-10-2002, 03:19 PM
dustin's Avatar
Default Re: gsr compression #'s...too low??? (GSR44)
You sure you did the test right?
Old 01-10-2002, 03:25 PM
BoM
BoM's Avatar
Default Re: gsr compression #'s...too low??? (dustin)
disconnect the distributor harness and disconnect the harness of the fuel...which is by the clutch inside.
then step on the gas and crank the engine several times
Old 01-10-2002, 04:27 PM
BTR ALL MOTOR's Avatar
since your compression is pretty equal between cylinders that can rule out some things. i would check the head gasket first, usually low compression is the head gasket when you are running the car real hard. Another thing i would check is the piston rings. Do a leak down test on all cylinders, if you are leaking some, that will also explain the low compression. Another thing you can check is the valve seals. But watch your coolant closely because if you are leaking coolant, and you have low compression, that is most likely a head gasket. Hope this helps...
Old 01-10-2002, 07:39 PM
GSR44's Avatar
Default Re: gsr compression #'s...too low??? (BTR ALL MOTOR)
yes...the test was done right...fuel injection fuse removed, all plugs out, accelerator floored, engine cranked at least 5 times. how much would i expect to pay for a leakdown test?
Old 01-11-2002, 12:10 AM
D-SPEED's Avatar
yes those numbers are low. i got 230 230 235 230 on my gsr...at least your numbers are consistent. I would have the leakdown test done as others suggested
Old 01-11-2002, 09:58 AM
dustin's Avatar
Default Re: gsr compression #'s...too low??? (D-SPEED)
I get 225 on all cyls, '95 gsr 51k miles.
Dustin
Boostn B20
11
11-27-2008 01:22 PM
smash fascism
10-27-2006 12:38 PM
97itr86
10-30-2004 08:51 AM
shadowdawn
10-11-2002 02:07 PM
Ri5e
02-10-2002 09:54 AM
Quick Reply: gsr compression #'s...too low???
