Everything I need to do/consider when putting a d16y8 head on a d16z6 block..
Old 08-25-2004, 10:53 PM
94dxt's Avatar
Default Everything I need to do/consider when putting a d16y8 head on a d16z6 block..
I'm putting a y8 head on a z6 bottom end. What all do I need to change? I konw about the upper left an upper right head bolt length diffderence but what about....Distributors? cam timing? head gaskets?...etc
Old 08-27-2004, 11:13 AM
94dxt's Avatar
Default Re: Everything I need to do/consider when putting a d16y8 head on a d16z6 block.. (94dxt)
Old 08-27-2004, 01:08 PM
94dxt's Avatar
Old 08-27-2004, 05:47 PM
94dxt's Avatar
help
Old 08-28-2004, 10:26 AM
94dxt's Avatar
Please
Old 08-28-2004, 02:46 PM
Carlito6's Avatar
I am not expert but by looking at the specs from this link https://honda-tech.com/zerothread?id=385741 it seems like you wouldnt have any piston-valve or any other clearance problems.... I am not familiar with the d16z6, is that the old vtech soch for the generation before the d16y8? then you would probably need to worry about the ECU and ODBII and also oiling system differences, also while you are it make sure you get the whole D16Y8 head, camshaft, cam gear, TIMING BELTS and COMPLETE IGNITION SYSTEM, or you could end up with a fried motor
Old 08-28-2004, 11:15 PM
CarsCarsCars's Avatar
Default Re: Everything I need to do/consider when putting a d16y8 head on a d16z6 block.. (Carlito6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carlito6 &raquo;</TD></TR><TR><TD CLASS="quote">I am not expert but by looking at the specs from this link https://honda-tech.com/zerothread?id=385741 it seems like you wouldnt have any piston-valve or any other clearance problems.... I am not familiar with the d16z6, is that the old vtech soch for the generation before the d16y8? then you would probably need to worry about the ECU and ODBII and also oiling system differences, also while you are it make sure you get the whole D16Y8 head, camshaft, cam gear, TIMING BELTS and COMPLETE IGNITION SYSTEM, or you could end up with a fried motor</TD></TR></TABLE>
It is the VTEC engine that was replaced by the d16y8. It was found in the EX and SI models from 92-95.
As for the stuff you would need. I agree with the ECU, OBDII issues, etc. But im not sure why you would need the complete ignition system. Lots of people run d16z6 IM on d16y8 because they are slightly more free flowing, so in the process i would think you could leave the d16z6 ignition system alone. Someone please correct me if im wrong, but this just seems logical to me.
Old 08-31-2004, 09:55 PM
94dxt's Avatar
Default Re: Everything I need to do/consider when putting a d16y8 head on a d16z6 block.. (CarsCarsCars)
I am wanting to use all of the z6 electronics. It will be a complete y8 head from the cam gear in. Everything else z6, will the distributor be an issue? I heard you can break off one of the pegs on the z6 dist (2 instead of 3) so that it will bolt to the y8 head/cam. What all do I need to do?
Old 09-01-2004, 10:15 AM
tgreaves's Avatar
If your interested in keeping with the same years.. I have a d16y7 motor that I was going to put a d16z6 head on.. If you wanna swap heads we can do that so youll have a full d16z6 and ill have almost a full d16y8..
Let me know..
vtec8200
05-04-2010 04:13 AM
memic
03-05-2005 08:48 PM
M.A.R.C.
11
11-23-2003 06:14 PM
Quick Reply: Everything I need to do/consider when putting a d16y8 head on a d16z6 block..
