d16y8 motor with the z6 cam what about timing?
my freind has a d16y8 motor , but broke his cam so put a d16z6 cam in it with the y8 cam gear, will the timing be the same as a y8 or a z6?
Re: d16y8 motor with the z6 cam what about timing? (alexsracing)
The cam keyway is 2 degrees out, I don't know which cam is which way. Ask a D-series cam maker that sells the cam for dual application, they should be able to tell you how you have to degree it...
-PHiZ
-PHiZ
i have been fighting with this for some time now. i put a crower z6 cam in my y8, with an aem adj cam gear. and haven't been able to get my timing right since. i emaild crower to ask the timing degree difference and this was there reply:
The Z series is 4 degrees retarded when compared to the Y.
Thanks for your interest in Crower,
Crower Cams & Equipment Co Inc
6180 Business Center Court
San Diego CA 92154-5604 USA
Phone: 619-661-6477
Fax: 619-661-6466
http://www.crower.com
i had trouble deciphering that. maybe its worded funny. maybe my brain is four degrees retarded.
Phone: 619-661-6477
Fax: 619-661-6466
