Could this possibly be an Input Shaft bearing issue?!??!
So my CRV makes a 'whining belt' noise while in neutral, and obviously after doing research found that if it makes the noise while the clutch pedal is up, and goes away with the clutch pedal floored...then it's the Input Shaft Bearing. This is true, however, the noise goes away even with the slightest feathering of the clutch pedal. I was under the impression that you had to fulling disengage by flooring the clutch pedal, at least halfway.
What's also odd is that when driving in gear the noise is present and if you feather the clutch while driving, the noise goes away. Is this normal for an Input Shaft noise issue? Or could this be related to the Throwout Bearing instead? Opinions and experiences definitely appreciated, before I start tearing off the tranny and clutch.
Thanks in advance guys.
mrmonk
03-25-2007 04:31 PM
