coolant temperature sending unit
where is it on a b16a motor, is it that sensor right under my vtec solenoid?
sometimes cooling fan kicks in, sometimes it doesnt at all and temp goes on the rise, i was told its the coolant temp sending unit, wondering were it is, thanks
Re: coolant temperature sending unit (mitchell_2kSiR)
It is not under the Vtec solenoid... Your can located the Coolant temp Sending unit on Thermostat housing.
You can always hot wire the fan to stay on.. but jumping the 2 wires together.
Re: coolant temperature sending unit (havok hybrid)
i pulled the plug under the vtec solenoid, and coolant came out and there are two wires coming from it . what plug is that then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitchell_2kSiR »</TD></TR><TR><TD CLASS="quote">i pulled the plug under the vtec solenoid, and coolant came out and there are two wires coming from it . what plug is that then?</TD></TR></TABLE>
That is also a engine coolant sensor.. The ecu uses that one.. The fan uses the one on the water neck at the thermostat .
Solbros Owns Me
ECT- Engine Coolant Temp sensor is on passenger side of head, 2 pin connector
Thermo Fan Switch is on the t-stat housing.
I pin sensor next to ECT is for the gauge cluster
EG92DX
10-04-2012 05:28 AM
mykem
11-16-2003 11:03 AM
Jason kiDD
11-30-2002 01:25 PM
