Compression ratio calculator - D16A6
Compression ratio and displacement calculator - D16A6
*EDIT* Found what I was looking for:
1) 38cc
2) -3.4cc (dished)
3) I used .000
Came up with 9.498, pretty close to stock 9.5
Sites that helped:
-http://raceseek.com/honda_specs.htm
-http://www.muller.net/sonny/crx/compression
I did a search and found this link: http://www.c-speedracing.com/howto/c...c/compcalc.php but it's only for B-series motors. I am trying to figure out the compression ratio and displacement for a D16A6 and I want to play around with some bore sizes.
I need to know the following things to use that calculator:
1) Combustion Chamber Volume
2) Piston Dome Displacement
3) Piston-to-Deck Height
[Modified by TheShocker, 10:20 AM 1/26/2003]
1) 38cc
2) -3.4cc (dished)
3) I used .000
Sites that helped:
Re: Compression ratio and displacement calculator - D16A6 (TheShocker)
https://honda-tech.com/zerothread?id=380264
stock compression in an a6 is 9.1:1 on the 4wd wagons and 9.2:1 on the 2wd a6s
Toptul_Honda
08-18-2003 09:55 PM
