F22B1 & tranny performance
Hello,
I am new at this and just strarting to learn mechanics, I am using my 96 accord as field practice.
Car is stock. Engine was overheated 3 years ago. Ran fine for 1 year and coolant started to leak. Head gasket job was done 2 years ago, since then engine is running fine.
I want to increase the performnace of the car, and low RPM torque. Eventually I am thinking to put a turbo. My questions are:
1. I am thinking to put sleeves to increase the bore size, donīt know the max size it can be reach safely, so I would like to know any expirences.
2. From the sleeves what is the expected torque and HP increase that I can expect
3. Is this going to increase the compression in the cilinders?
4. Would this allow me to put a turbo later?
5. I do not what is the Max HP & rtoruqe that I can expect to put safely in this engine, I expect to use the car almost daily, what are the the max HP I can reach safely using a turbo. is 300 - 350 HP too much?, if this is acceptable what additional work tyhe engine needs.
6. The stock transamission will stand the new power?, I am about to change the CP, PP and flywheel.
Thanks a lot for all comments
