burping coolant system by running car with heater on and no radiator cap--how long?
Old 08-24-2005, 11:31 PM
BlueShadow's Avatar
Default burping coolant system by running car with heater on and no radiator cap--how long?
Hi guys,
I need to make sure all the air is out of the coolant system cause I just refilled it. My water outlet didn't have the bleed screw so I have to burp the system by runnin it with no rad cap.
My question is how long do I ned to keep it running until I can stop? Right now the coolant is all the way to the radiator neck. So should I just run the car until it is fully warmed up, or should I run it for a certain amount of time? in either case the coolant would start overflowing out the rad cap, so do I just ignore it and keep running the motor?
TIA
Old 08-25-2005, 06:57 AM
JimBlake's Avatar
Default Re: burping coolant system by running car with heater on and no radiator cap--how long? (BlueShadow)
I just watch the water in the radiator neck, so it doesn't overflow. I also push & squeeze the radiator hoses to push air bubbles over one way or the other. If your cap & reservoir bottle are working correctly, the last little bubbles should work out the next couple times you drive.
After having it open, I check the hoses every day or so until they're full. When you squeeze the hoses cold, you can hear whether there's air sloshing around in there.
Old 08-26-2005, 05:00 AM
BlueShadow's Avatar
Default Re: burping coolant system by running car with heater on and no radiator cap--how long? (JimBlake)
Yup, I "massage" the upper radiator hose too to get the air bubbles outand fluid to go down. I think I got most of the air bubbles out now since I've driven the car around for a bit.
Old 09-01-2005, 07:08 PM
NitroStickers's Avatar
im curious to, i just did a flush on my system, i refilled it and ready to bleed. i let car run with heat on and the nipple open, foam was coming out and then just nothing. i thought your supposed to get straight fluid come out streamin???????????
Old 09-02-2005, 12:01 PM
95lstegman's Avatar
Default Re: burping coolant system by running car with heater on and no radiator cap--how long? (NitroSticke
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitroStickers &raquo;</TD></TR><TR><TD CLASS="quote">im curious to, i just did a flush on my system, i refilled it and ready to bleed. i let car run with heat on and the nipple open, foam was coming out and then just nothing. i thought your supposed to get straight fluid come out streamin??????????? </TD></TR></TABLE>
can you see fluid at the radiator neck? maybe it's just very low . . . tell you guys the truth, i never use the bleed screw. i run it for about 5 mins w/heater on full hot, shut it off, leave it alone and next time it's cool and i'm thinking about it and in the mood i check the level and top off if needed. it only goes down a little tiny bit, and your car will stay cool with only half of its coolant capacity.
Old 09-02-2005, 02:35 PM
yes its filled to the top.
Empyre JDM
05-11-2010 12:51 PM
B18c1vicrx
05-13-2009 01:01 PM
corince06
06-11-2008 12:48 PM
gsrcxhatch
05-11-2006 07:37 PM
drumsy
09-12-2002 07:14 AM
Quick Reply: burping coolant system by running car with heater on and no radiator cap--how long?
