b16: tps adjusment voltaqge
ive searched and i know the voltage needs to be as follows:
Closed is .45-.50
WOT is 4.5-5.0
How do i adjust this?
I just replaced my tps but still isnt idling nor driving correct way
Closed is .45-.50
WOT is 4.5-5.0
Re: b16: tps adjusment voltaqge (slomofo)
how can i check the voltage the best way possible and the bottom peice where the screw screws into is broken can it make a difference if its only tighten by one screw?
Re: (slomofo)
do i do this when car is idling or when just the igntion is on?
Also i see there's two different voltages, one is idle another is at WOT how do i setup both? Thanks
Please also explain a little better the way i connect the wires
iphatcrxi
10-05-2006 08:49 AM
kholmes
10-12-2004 06:59 PM
