Synchro Rings or Sleeve sets ???
Old 09-24-2004, 05:00 PM
NXSpoon's Avatar
Default Synchro Rings or Sleeve sets ???
OK, I am in the process of rebuilding a Type R tranny. Now I was told that the 4th gear synchro was in need of replacement and that the tranny has ~40k miles on it and has been to the dragstrip. I figure while I have it apart, I will replace all the synchros, seals and bearings just to be on the safe side. Don't ask, this is how I am.
The gears themselves look OK, as do all the other synchros. I am getting my friend to give me a second opinion.
What is the difference between a synchro ring, and a sleeve set?? Other than a whole lot more parts. Do I really need to get a sleeve set, or just some individual syncro rings?? I notice that some of the grey looking rings in the sleeve have the same teeth that the synchro rings have. They show little to no wear.
Thanks,
Ken
Old 09-25-2004, 12:13 AM
murtnabila's Avatar
Default Re: Synchro Rings or Sleeve sets ??? (NXSpoon)
bump 4 u
Old 09-25-2004, 08:42 PM
NXSpoon's Avatar
Default Re: Synchro Rings or Sleeve sets ??? (murtnabila)
Bump for me because I really want to learn.
Old 09-25-2004, 09:00 PM
Kamin's Avatar
the sleeve is the entire syncro assembly inside the sleeve that the shift fork goes around. the syncros are just the parts that would go inside the sleeve.
Old 09-25-2004, 09:27 PM
NXSpoon's Avatar
Default Re: Synchro Rings or Sleeve sets ??? (Kamin)
So when people get "new synchros", do you think that they are getting just the brass synchro rings replaced or new sleeve sets?
murtnabila's Avatar
so u would have to get the sleeve and synchros in a rebuild?
Old 09-25-2004, 09:37 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXSpoon &raquo;</TD></TR><TR><TD CLASS="quote">So when people get "new synchros", do you think that they are getting just the brass synchro rings replaced or new sleeve sets?</TD></TR></TABLE>
depends on the shop doing the work. since most shops are cheapasses, probably just syncros. sleeves shouldnt be damaged from wear, only the syncros.
Old 09-25-2004, 09:57 PM
NXSpoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
depends on the shop doing the work. since most shops are cheapasses, probably just syncros. sleeves shouldnt be damaged from wear, only the syncros. </TD></TR></TABLE>
Great, I'll be doing the work and I am not a cheapass. But even I find it wasteful to replace ~$500 worth of sleeve sets if I only need to replace the rings.
Thanks.
hybrid1990crx
04-05-2011 07:47 PM
PARADOX_sf
01-03-2011 08:17 PM
RACEPAK
08-30-2008 09:59 PM
vmoua509
10-10-2004 12:58 PM
94gsr
05-09-2002 07:36 PM
Quick Reply: Synchro Rings or Sleeve sets ???
