Need info for my engine build....
Old 12-11-2005, 03:54 PM
AFTERZERO's Avatar
Default Need info for my engine build....
This winter I plan on building my motor and I wanna get some info before I start the build. The motor that Im building is a b18c1 with a b16a head. I want to get the block re-sleeved and go with some high compression pistons. The car will only be driven on the weekends, some tracking days, little drag racing and I still want to be able to run on 93 octane.
Now my questions:
What company is the best for the buck for resleeving?
What pistons and rods should I go with?
Any good and bad experiences?
What is the best tuning ecu?
The head will be sent to portflow, omni power valves etc, and jun 3 cams.
Any info or advice from experience will be very helpful.
Old 12-11-2005, 04:07 PM
SVOboy's Avatar
Best ecu is P28, obd1 of course, but you can also go for p72 or p30 for knock junk but who cares. P28 is most common I guess I should say.
Old 12-11-2005, 04:12 PM
AFTERZERO's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Best ecu is P28, obd1 of course, but you can also go for p72 or p30 for knock junk but who cares. P28 is most common I guess I should say.</TD></TR></TABLE>
Well I prob wanna go with hondata, wich system is better for an all motor setup, the s100 200 or 300?
Modified by AFTERZERO at 1:22 AM 12/12/2005
Old 12-11-2005, 10:22 PM
AFTERZERO's Avatar
Default Re: (AFTERZERO)
Old 12-12-2005, 08:16 AM
SVOboy's Avatar
s300, :-P
Old 12-12-2005, 10:14 PM
AFTERZERO's Avatar
Im leaning towards eagle sleeves....anybody have some helpful info
Bc1r6x
03-27-2007 07:49 PM
dr@ke
15
10-27-2006 09:46 PM
TurboEM1
08-10-2006 08:54 PM
poooch
07-30-2006 10:53 PM
HamiltonRex
12-05-2003 09:53 AM
Quick Reply: Need info for my engine build....
