Adjusting throttle stop?
Hey guys, as you may know my BBK 62mm TB has been sticking open a little ever since I installed it. If you punch the throttle, you can get it to close. Somebody suggested I might need to adjust the throttle stop screw. Is there a rule of thumb used for doing this?
I.E. should the throttle plate be completely shut, open a little, etc?
Re: Adjusting throttle stop? (mplex2000)
get the motor warm so it will idle then turn the screw into the thortle stop till the RPM goes up thn back it off a little you will have to do this slowly and listen carefuly to the motor then snap the throtle to see if its still sticken you will feel it stick!!! use a 7mm to lossen the nut ! and the alen key that comes with aftermarket shift *****
[Modified by lowsol, 9:20 AM 4/2/2002]
dth0ng69
05-09-2009 05:47 PM
Mr. JDM-GSR
08-29-2005 11:33 AM
