95 integra gsr electrical problem need help asap
Old 06-12-2016, 02:59 PM
Borintegra's Avatar
Default 95 integra gsr electrical problem need help asap
Like the title states I have a Jdm front integra gsr , the front end was recently installed then my brake light and horn fuse keeps poppin . My brake lights don't work however everything else does . I replaced the fuse boxes and the floor harness in the car . Somehow the brake light wire is getting direct power. Any help or suggestions will be appreciated . Thanks
Old 06-12-2016, 03:38 PM
2point1's Avatar
Default Re: 95 integra gsr electrical problem need help asap
Try unplugging the brake switch plug and see if the fuse still blows with it unplugged.
Old 06-12-2016, 04:06 PM
fcm
Old Fart
fcm's Avatar
When does the fuse blow, as soon as you install it, when you turn on the ign. or when you use the brake or horn?
What MM&Y of car did the fuse boxes and floor harness come out of?
When you say, "My brake lights don't work" and "Somehow the brake light wire is" getting direct power" does that mean they stay on all the time? 94
Old 06-12-2016, 05:42 PM
Borintegra's Avatar
My car is a 95 integra gsr it had the usdm front and I had no electrical issues at the time . Since installing the Jdm itr front end I noticed that my brake lights don't turn on when braking . My taillights work and everything else works fine . The fuse pops even if I don't engage the brake pedal. The fuse boxes got replaced and the new fuse boxes came from another 95 integra gsr . It seems like there's direct power going to the ( brake / horn harness) wire . Every socket and connection in the car are unplugged and fuse still blows. Need serious help .
Old 06-13-2016, 11:45 AM
fcm
Old Fart
fcm's Avatar
That is going to be a tough one the brake light circuit does not go to the front of the car, but the horn circuit does, check the white/green power lead to the horn(s), my guess is it is shorting to ground at some point. 94
Old 06-13-2016, 03:28 PM
Borintegra's Avatar
Thanks bro , I'll check it out and will post updates . I appreciate it
Old 06-14-2016, 04:48 PM
Borintegra's Avatar
A quick update on my car , I bought the snap on short circuit finder tool and it apparently worked. The short was caused by a faulty sunroof switch which was causing a bad ground. My car sat in a repair shop for about a year and they couldn't find the problem but thank God I did . Thanks to all of you guys for the support as well.
Old 06-15-2016, 09:01 AM
fcm
Old Fart
fcm's Avatar
So sunroof is also on that fuse?
Kind of weird that the sunroof is on a 12V constant power circuit like brakes and horn. 94
01civicex01
Honda Civic (2001 - 2005)
08-01-2017 12:58 PM
DerekHollister
04-04-2016 02:06 AM
ek4_b16a
07-02-2009 10:20 AM
_RedRiceR_
12-21-2004 05:23 PM
b16a2pwr
02-14-2004 02:28 PM
Quick Reply: 95 integra gsr electrical problem need help asap
