120 psi compression test d16y8
hi please I need some help
I have a civic 98 ex MT with 82.000 km
I research and found that 135 is the lowest and 180 is normal...
well the thing is I did compression test and all the cylinder have 120 psi...
I did the compression test with the engine cold and hot and WOT...
I put some oil and raise 140 - 150...
the engine run fine idle fine but sometimes hesitaste and bog between 1500 to 3000 rpm...
what do you think guys???? thank`s a lot for any help...
Re: 120 psi compression test d16y8
thank`s for your answer...
I live in caracas venezuela, altittude is 900 meter...
do you think the altittude is the reason for the low compression???
120 psi across the 4 cilynder...
JConto
12
02-23-2010 10:01 AM
yoffer
04-03-2007 08:34 PM
