Suspension & Brakes Theory, alignment, spring rates....
Loud clicking noise when breaking
Old 09-07-2013, 05:02 PM
Hypnotise305's Avatar
Default Loud clicking noise when breaking
When I apply the brakes slowly I get a clicking sound... and as I slow down the clicks get much louder. The noise gets louder until I approach 0 mph. The noise is definitely coming from the front of the car, I believe the drivers side. If I stop abruptly or apply the brakes strong...no sound at all. I was hoping someone might have had a similar experience or might be able to shed some light.
Things I've checked;
Axles
Tierods
Rotors
Brake Pads
Old 09-07-2013, 05:06 PM
90_EX_Civic's Avatar
Default Re: Loud clicking noise when breaking
check to make sure the calipers and caliper bracket is on tight?
Old 09-07-2013, 05:15 PM
Has been taken off and tightened several times, wasn't the cause. Not sure if calipers would cause the clicking.
Old 09-07-2013, 05:25 PM
jdmh22eg2's Avatar
brake pad clips/hardware?
Old 09-08-2013, 11:35 AM
Check them. Isn't the brake pad clips or hardware but the clips are old as hell and still could use replacing.
Old 09-08-2013, 12:20 PM
sweesiong78's Avatar
have you checked if the caliper slide pins are lubed and sliding freely? I had a similar noise and found that the grease on the slide pins had dried up.
Old 09-15-2013, 04:49 PM
1998GsRIntegra's Avatar
I've experienced something very similar before. For me, it was a bad caliper. I'm using legend gs dual piston calipers and rotors up front and one of the pistons in the front right caliper locked up for some unknown reason. It created what I would describe as a bind then pop kind of thing when braking lightly at lower speeds. Pulling the caliper and compressing the pistons to free them up would fix the problem for a short while but I just ended up replacing the caliper when it was convenient. Problem has been gone ever since.
xintegr
05-08-2007 11:18 PM
h23vtak
09-24-2006 09:47 AM
Slvr_CRX
10-18-2004 10:48 AM
Red Ride
04-18-2003 08:02 AM
Shorthand
01-06-2003 09:14 PM
Quick Reply: Loud clicking noise when breaking
