Suspension & Brakes Theory, alignment, spring rates....
ground control, which one??
Old 05-21-2007, 11:32 AM
pos_cd5's Avatar
Default ground control, which one??
im looking at GC springs for a '00 civic dx hatch and they have like 4 different kinds. regular, drag racing, motor swap, and road racing. what is the diference between them all, i know for the drag and road race spring you can get them in any rate you want, but they also say if your unsure of what rate you want, give them a brief description and they will choose a rate for you, how does that work? and whats the rates for just the regular springs, are they more performance oriented or daily/spirited driving, and whats the difference for the motor swaped springs, just higher rates int he front for the extra weight?
Old 05-21-2007, 11:38 AM
Tyson's Avatar
Default Re: ground control, which one?? (pos_cd5)
have you tried calling ground control?
Old 05-21-2007, 11:46 AM
pos_cd5's Avatar
Default Re: ground control, which one?? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">have you tried calling ground control?</TD></TR></TABLE>
no
Old 05-21-2007, 11:52 AM
Resident Hoser #1
CAN97SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">but they also say if your unsure of what rate you want, give them a brief description and they will choose a rate for you, how does that work? </TD></TR></TABLE>
Just give them a call and they will give you advice as to what rates are best for you. It really all depends on how you drive, if you're using your car for drag racing, autox, tracks, or just daily driving. It also depends on how strong your back is because the stiffer you go the harsher the ride.
If you call them they will be able to give better advice.
Old 05-21-2007, 11:52 PM
bmoua's Avatar
you can get the reg. bro. If you want a stiffer ride then get the custom spring rates...
Cole D
Suspension & Brakes
10
07-10-2007 07:05 AM
TheTealHatch
Suspension & Brakes
13
01-20-2007 12:17 AM
92hatchattack
Suspension & Brakes
05-12-2006 08:28 PM
ziggen243
Suspension & Brakes
11-08-2005 11:58 AM
igone916
13
02-27-2004 01:01 AM
Quick Reply: ground control, which one??
