What is this port on the water pump, can i block it?.
Old 02-18-2017, 03:46 PM
B_Swapped93's Avatar
Default What is this port on the water pump, can i block it?.
I took the nipple out, that had a small hose on it, it would have ran to the stock k20A2 intake manifold. I've got the ktuned manifold now, but before I put it on, i'd like to know what that port is and if I can block it off. And if I can't, what CAN I do with it, I see no where on the manifold to put an oil? line into.
Old 02-18-2017, 10:11 PM
stayontrack's Avatar
Default Re: What is this port on the water pump, can i block it?.
pcv valve
Old 02-19-2017, 06:33 AM
Originally Posted by stayontrack
pcv valve
thank you, I got rid of mine on any of the B series I had back in the day. I'm assuming it's ok to just put the bolt in there, nothing else needs to be done?
Old 02-19-2017, 08:24 AM
been there done that
doood's Avatar
If you block that off I would run at least a catch can off the valve cover
alupso
01-22-2009 10:00 AM
EfJosh
12-14-2008 08:41 AM
mr_gs-r
12-05-2007 04:56 AM
Chuji
08-19-2002 01:52 PM
Quick Reply: What is this port on the water pump, can i block it?.
