CRZ OFFSETS
CRZ OFFSETS
What are the average offset on the crz around here? I'm into the hellaflush scene because obviously i bought this car to save gas so i can spend it on tires . Please post up a picture and offset please!! :D
Re: CRZ OFFSETS
Im running 17x9 +38 in front and 17x9.5 +38 in rear and it required rear bumper mount modification as well as camber in front to fit. Running camber bolts top and bottom.
Re: CRZ OFFSETS
Wow that's sexy I drove one of these at work yesterday for the first time that **** gets it for a hybrid I was very surprised
Re: CRZ OFFSETS
looks nice bro! i was planning on running 18x9.5 +22! i think thats going to be perfect then compare to your offset! thanks for the help!
Re: CRZ OFFSETS
To answer the original question the stock wheels are +45 offset, in either a 6" wide standard or 6.5" wide optional oem wheel. The front wheels are flush at about 15-20mm lower offset than stock, and the rears at 30-35mm. If you want a flush look in back and no poke in front youll have to run spacers in the rear or a staggered setup, since the rears are much more sunk in.
Also if you lower the car on anything wider than stock wheels, you will probably need to run slightly stretched tires, negative camber and/or roll and shave the inside of the fenders. This car is not friendly for aggressive fitments, but it can be done.
Re: CRZ OFFSETS
Phizstuh - No Fake Wheels Please!
Car looks good Justin... i'm going with 17x9.5 +38 with 225's all around on my setup... NT03 Hella Flush!
- Basis Sport Tony
- Basis Sport Tony
Re: CRZ OFFSETS
Here are some Advan RGII wheels.
17×9.5 +35 all around
215/40f
225/40r
This is on one of our riders CRZs. Check out some info and some photos of his car here...
Link: http://www.autocityimports.com/blog/2012/cr-z-bagged/
215/40f
225/40r
